340 Carter AVS BAse Gasket #2527737
07/27/18 07:37 AM
07/27/18 07:37 AM
Armada MICH.
DUSTER_340 Offline OP
Armada MICH.
Looking for pictures or confirmation on what base gasket was used with an AVS on a 340 between 1968 and 1970. I have what I am going to call an untouched 68 340 with nothing more than a thin gasket, but I have read others have seen thicker gaskets .
TIA
Re: 340 Carter AVS BAse Gasket [Re: DUSTER_340] #2527803
07/27/18 11:37 AM
07/27/18 11:37 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Think its just a thin paper.
Not writing paper thin, but more like manila enveloper paper thin
Re: 340 Carter AVS BAse Gasket [Re: DUSTER_340] #2527811
07/27/18 11:49 AM
07/27/18 11:49 AM
Greenwood Lake, NY
fuelishnsilly Offline
Greenwood Lake, NY
What was the thicker cardboard carb gaskets used on that come with the rebuild kits?
inherited a 69 roadrunner from my grand pop.
Re: 340 Carter AVS BAse Gasket [Re: DUSTER_340] #2528863
07/30/18 12:40 AM
07/30/18 12:40 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Edelbrock makes a heat insulation gasket that is thick and works well. I am pretty sure originally the 340 cars had a thick carb to intake gasket.
Re: 340 Carter AVS BAse Gasket [Re: DUSTER_340] #2529033
07/30/18 02:18 PM
07/30/18 02:18 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
1/4" thick with a plastic insert for the bolts.
Choke linkage adjustment requires it.
