Re: I need Dana 60 setup help... Badly
[Re: mcat4321]
#2527590
07/26/18 09:06 PM
07/26/18 09:06 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
wrong Carrier for the 3.54 gear you have
[Re: mcat4321]
#2527606
07/26/18 09:41 PM
07/26/18 09:41 PM
Posts: 8,237 fredericksburg,va
cudaman1969
fredericksburg,va
Pinion turning without the carrier? If all the shims are out, behind bearing-race, on the other side of ring gear, you have the wrong carrier. S60 is the same as reg 60 other than the adjusters-- is that scwewed all the way back? Not sure you need shims on a S60 now that I think if it. It adjusts like an 8-3/4. 3.54- 4.10 use same carrier, 4.56 and up use the thicker one.
[Re: mcat4321]
#2527711
07/27/18 01:38 AM
07/27/18 01:38 AM
Posts: 11,531 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
2.225" = 4.10 and down 2.420" = 4.56 and up I see gear sets with "thick" ring gears available for most ratios 4.56 and above, made for use on the 4.10 carrier.
[Re: mcat4321]
#2527774
07/27/18 10:33 AM
07/27/18 10:33 AM
Posts: 3,101 cincinnati ohio
mcat4321
cincinnati ohio
Thank you... the 410 and the 373 were both richmond..the 354 is a dana, looks like the 373 will have to do... thank you thank thank you... I was worried I was just stupid
