Page 2 of 7 1 2 3 4 5 6 7
Re: Unexpected Dyno Results [Re: MarkZ] #2527204
07/26/18 01:10 AM
07/26/18 01:10 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
As mentioned, chassis dynos and automatics can produce strange results, especially with a loose converter.
Looks to me like your converter slipped to around 5300 RPM, where both curves hook, and your TQ and HP were already falling off. I think its very unlikely that engine peaks torque at 5300 RPM.
What exactly is the converter? According to TA that converter is for a late model Hemi or Magnum setup... if this is the correct converter its going to stall way higher than it is designed to stall behind a 318-360 cubic inch engine.
Re: Unexpected Dyno Results [Re: MarkZ] #2527209
07/26/18 01:19 AM
07/26/18 01:19 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Tq and hp are always exactly the same, and cross paths at 5252rpm.
Re: Unexpected Dyno Results [Re: MarkZ] #2527232
07/26/18 03:07 AM
07/26/18 03:07 AM
AndyF Online content
AndyF  Online Content
I think you have a great combo for the street. Get out there and enjoy it this summer and then decide if you really want to change it. A bigger cam will make more peak power but you might lose some low end torque. Drive it for a while to see what you think before you make up your mind. You might just like the smooth idle and bottom end grunt that you get with a smaller cam.
Re: Unexpected Dyno Results [Re: MarkZ] #2527279
07/26/18 11:02 AM
07/26/18 11:02 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
with this combo I would be cautious about over gearing and too loose of a converter. on an engine dyno this engine may show close to 550hp. i'd try to sneak up on the total timing some; maybe try 36-37 degrees. you can get 2 1/2" mufflers that will flow better than some 3". I wouldn't get lost in the peak horsepower/rpm thing. whatever gains you might be making above 5200rpm may be ate up driving the trans/axle. chassis dyno thing is a different world than the more common engine dyno numbers. in my opinion, chassis dyno is real world and engine dyno can be more pie in the sky.
Re: Unexpected Dyno Results [Re: MarkZ] #2527309
07/26/18 12:09 PM
07/26/18 12:09 PM
Minn
SportF Offline
SportF  Offline
Minn
Why is everybody afraid to try and put some timing in it? Is it an internet myth or something?
Re: Unexpected Dyno Results [Re: SportF] #2527379
07/26/18 02:21 PM
07/26/18 02:21 PM
I've tested BB ignition timing many at the track and on multiple race gas and pump gas engines on a engine dyno, all of the ones I tested like between 34 and 36 BTDC total timing for the best ET, MPH and HP and torque on the dyno.
This is with the TDC verified to make sure zero on the timing tab and balancer where accurate, I have found many engines that they where off also shock work
I raced a 1963 415 HP Max Wedge car in NHRA stock for many years, a friend and fellow SS racer had a 1963 Savoy 415 M.W. he raced in Super Stock and swore his motor liked 42 degrees total timing shruggy I learned later he didn't build his motors and it had a late model timing cover with a early dampener, which ends up indicating 10 degree more timing than actual work shruggy
IHTHs up
Re: Unexpected Dyno Results [Re: MarkZ] #2527395
07/26/18 02:35 PM
07/26/18 02:35 PM
So. Burlington, Vt.
So. Burlington, Vt.
Here’s that one from last fall, with a 2” super sucker on it:
Re: Unexpected Dyno Results [Re: MarkZ] #2527400
07/26/18 02:40 PM
07/26/18 02:40 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Pulling up his runs out and doing the conversion to mph and looking at comparing to rpm and doing the math this thing is just blowing threw converter. looking at the graft you can see it is trying to couple up then it finally does when it starts running out of power.
JAKES AUTOMOTIVE
Re: Unexpected Dyno Results [Re: JAKE68] #2527534
07/26/18 07:21 PM
07/26/18 07:21 PM
Does the dyno have the ability to plot drum RPM vs. engine RPM? That would probably show what is going on.
Re: Unexpected Dyno Results [Re: MarkZ] #2527537
07/26/18 07:28 PM
07/26/18 07:28 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Andy that's basically what we did and came up with the results. I didn't know how to do that so when my dyno operator came in and he did it and showed me.
JAKES AUTOMOTIVE
Re: Unexpected Dyno Results [Re: JAKE68] #2527571
07/26/18 08:30 PM
07/26/18 08:30 PM
So just to take a guess, at 3000 engine rpm the drum is barely moving. Since the drum is barely moving the recorded HP is low, but really the engine is making a bunch of power. It is just the that engine power is being absorbed by the torque converter (turned to heat in the tranny fluid) rather than turning the drum.
If that is what is going on then he needs a much tighter converter. Maybe a stock Hemi converter or something even stouter like a truck converter. With 500 inches and a small cam there is going to be a lot of torque on hand right off idle.
Re: Unexpected Dyno Results [Re: MarkZ] #2527574
07/26/18 08:41 PM
07/26/18 08:41 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
I don't think that that converter was designed for that much torque and it would not couple up. I would think that it just needs a converter more designed for that application and not one that was met for a small block. he probably could still get by with something that would be in the 3200-3800 rpm.
JAKES AUTOMOTIVE
Re: Unexpected Dyno Results [Re: MarkZ] #2527579
07/26/18 08:51 PM
07/26/18 08:51 PM
So. Burlington, Vt.
So. Burlington, Vt.
AFAIK, the dynojet doesn’t have any load cell to “take a reading” and measure torque.
It uses a formula to calculate the speed differential over time, and calculates how much power it takes to accelerate the drum(which has a known mass) that amount, in that amount of time(not a good description I know).
Basically, the rate of acceleration is what’s used to calculate the power.
It’s an inertia dyno.
If you run two cars with noticeably different power levels, say 100hp and 800hp, through the same rpm range(like 2500-6500), you’d notice the lower power car took much longer to get from 2500-6500.
The only thing controlling the “rate” is the weight of the drums and the output of the motor.
More power accelerates the drum faster.
I’m not sure all dyno jets operate this way, but the one my friends have does.
Edit: I did a little search and it appears Dynojet does offer some of their dynos with eddy current loading, along with the inertia loading.
With eddy current loading, it would be capable of taking an actual torque reading.
Re: Unexpected Dyno Results [Re: MarkZ] #2527582
07/26/18 08:52 PM
07/26/18 08:52 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Something is wrong.
Not only are the numbers disappointing, the torque curve should NEVER have a big spike like that.
Boffin Emeritus
Re: Unexpected Dyno Results [Re: fast68plymouth] #2527587
07/26/18 09:01 PM
07/26/18 09:01 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Originally Posted By fast68plymouth
AFAIK, the dyno jet doesn’t have any load cell to “take a reading” and measure torque.
You are correct. they do have a load cell option but I have never seen one, every one I have used & seen was just the drum.
Re: Unexpected Dyno Results [Re: MarkZ] #2527593
07/26/18 09:10 PM
07/26/18 09:10 PM
So. Burlington, Vt.
So. Burlington, Vt.
I know of a few cars that got run over at my friends shop where the numbers just didn’t make sense(weren’t right).
One that comes to mind was a 69 charger with a 446. Rpm heads, 509 cam, headers, 850 demon carb, 3.91’s, 10” converter.
It was something silly like 285hp.
The car actually ran pretty good on the street. This was an all steel, full interior street car.
Had to weigh at least 3800 with driver.
Went high 11’s at the track.
That’s not 285rwhp doing that.
Re: Unexpected Dyno Results [Re: MarkZ] #2527781
07/27/18 10:39 AM
07/27/18 10:39 AM
an8sec70cuda Offline
FWIW...my cuda made 636 hp and 555 ft lbs of torque on the local Dynojet.
Ran 9.54 at 140.4 mph at 3800 lbs in that configuration.
Outran a bunch of supposed 800+ hp at the wheels cars too.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Unexpected Dyno Results [Re: MarkZ] #2527786
07/27/18 10:48 AM
07/27/18 10:48 AM
UK
rb446 Offline
rb446  Offline
UK
866Fwhp
60 Foot E.T. : 1.33
1/8 Mile E.T. : 6.02
1/8 Mile Trap Speed : 112.96
1/4 Mile E.T. : 9.54
1/4 Mile Trap Speed : 140
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: Unexpected Dyno Results [Re: rb446] #2527787
07/27/18 10:50 AM
07/27/18 10:50 AM
Originally Posted By rb446
866Fwhp
60 Foot E.T. : 1.33
up It actually went 1.320 to the 60' and 6.05 at 112.9 to the 1/8. Your calculations look good to me, lol. Always figured it was in the 850 hp range.
CHIP
Re: Unexpected Dyno Results [Re: MarkZ] #2527791
07/27/18 10:56 AM
07/27/18 10:56 AM
UK
rb446 Offline
rb446  Offline
UK
Wallace calc, but only 1 of them, been using it for years, has been pretty accurate for my old cars and others....Moroso chart differs, less hp etc.
http://www.wallaceracing.com/accel-calc.php
Input weight and then adjust hp no.
