ID This NOS Trim Clip
#2526827
07/25/18 12:12 PM
07/25/18 12:12 PM
Posts: 806 Mechanicsburg, PA
LemonTwiist
Mechanicsburg, PA
Can some one please tell me what this clip is for. I have some NOS clips that are in the original bags, but don't know what they fit. It is 3-1/4" long. Thanks
Re: ID This NOS Trim Clip
[Re: NANKET]
#2527937
07/27/18 04:19 PM
07/27/18 04:19 PM
LemonTwiist
Mechanicsburg, PA
The upper door woodgrain on 70 GTX has clips similar to those, been a while since I looked at them. You can carefully compress the tabs and reuse the clips. That being the case when you see used panels for sale the clips are never with them probably get torn off on removal. You are correct. I got the answer on for b-bodies only dot com
[Re: LemonTwiist]
#2528982
07/30/18 12:25 PM
07/30/18 12:25 PM
Posts: 2,918 Calgary, Alberta Canada
a12rag
The upper door woodgrain on 70 GTX has clips similar to those, been a while since I looked at them. You can carefully compress the tabs and reuse the clips. That being the case when you see used panels for sale the clips are never with them probably get torn off on removal. You are correct. I got the answer on for b-bodies only dot com You just have to be careful when disassembling the GTX or Sport Satellite these belong to . . . and ready to donate blood from the slices to your arm from the sharp metal edges of the openings in the door . . .
