Re: Old Manley Thunderstick Cams?
[Re: Porter67]
#2526948
07/25/18 03:36 PM
07/25/18 03:36 PM
Posts: 8,285 fredericksburg,va
cudaman1969
fredericksburg,va
Had one similar in my 69 RR 383 4 speed. Kept kicking pushrods till I used adj Isky rockers. Last time it kicked the pushrod, lost oil pressure and piggy backed a rod bearing. Still have the 383 & 4 speed, car long gone, to my dismay. Has manly pistons, pop ups.
[Re: Porter67]
#2527203
07/26/18 01:03 AM
07/26/18 01:03 AM
Posts: 14,504 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
From what I remember about them....... they were just another source for the “white box specials” coming out of the big cam suppliers(camshaft machine, etc).
[Re: Porter67]
#2527333
07/26/18 12:50 PM
07/26/18 12:50 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
Not much lift with just a little more duration than the old hemi cams, I believe they were 222 @ .050.
Have a great day Iowan
"obsolete is neat"
[Re: Porter67]
#2527516
07/26/18 06:40 PM
07/26/18 06:40 PM
Guitar Jones
Not sure what you are looking for but I stuck the biggest Summit cam for a small block in my 360. Runs very good but does not sound like it has a cam in it. Real smooth with 14* initial and 35* total on the mechanical.
[Re: Guitar Jones]
#2527560
07/26/18 08:07 PM
07/26/18 08:07 PM
Porter67
I just got alot of old school parts stashed away and ive two stroker motors in two of my cars, freshen a few up a year for friends and im actually just having fun working with a couple low power buids with oem blocks and head castings to see how things run and what I can do to improve on them. I dont recall a day when very young that a warmed over mill still didnt make for a decent time. Not sure what you are looking for but I stuck the biggest Summit cam for a small block in my 360. Runs very good but does not sound like it has a cam in it. Real smooth with 14* initial and 35* total on the mechanical.
