Installing Alternator pulley's #2525272
07/22/18 11:47 AM
07/22/18 11:47 AM
Michigan, USA
sixpackman Offline OP
Michigan, USA
Hello,
I found the correct alternator for my AAR but is missing the pulley. I read somewhere that I need to remove the rear case to be able to press the pulley on? Any feedback would be greatly appreciated.
Thanks,
Re: Installing Alternator pulley's [Re: sixpackman] #2525280
07/22/18 12:02 PM
07/22/18 12:02 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Yes the rea case must be removed to press the pulley on.I have done 1 or 2 without splitting then though.The first one I ever did years ago i messed up the rear bearing pressing one on without splitting the case.Just mark them split the case and press it on.Rocky
Chrysler Firepower
Re: Installing Alternator pulley's [Re: therocks] #2525318
07/22/18 01:17 PM
07/22/18 01:17 PM
Yes make 2 magic marker marks on each outer case half for easy (re)alignment when done. When the wife ain't looking put it in the freezer overnight & slightly heat the pulley then support the rear of the shaft & carefully press it on.
Re: Installing Alternator pulley's [Re: sixpackman] #2525324
07/22/18 01:36 PM
07/22/18 01:36 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Originally Posted By sixpackman
Hello,
Thanks,
I use to go thru the BS of disassembling the cases to change pullies, but found it far easier to go to my local AutoZone or NAPA, they'd have it changed out in lest than five minutes without pulling it apart, no charge (although good to grease the guys palm) and at times not even purchasing the alternator there....
Re: Installing Alternator pulley's [Re: DAYCLONA] #2525844
07/23/18 01:24 PM
07/23/18 01:24 PM
moparx Offline
moparx  Offline
any time i tried to press on an alternator pully with it fully assembled, i wanked up the rear bearing. flame what could i have done wrong ? i supported it correctly ...... i think. even using a heated pulley.
beer
Re: Installing Alternator pulley's [Re: DAYCLONA] #2525896
07/23/18 03:35 PM
07/23/18 03:35 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Hmmm.
Re: Installing Alternator pulley's [Re: John_Kunkel] #2525920
07/23/18 04:20 PM
07/23/18 04:20 PM
I didn't think the shaft is threaded like a crankshaft but if so, the same type of threaded tool could draw the pulley on
Re: Installing Alternator pulley's [Re: RapidRobert] #2525965
07/23/18 05:28 PM
07/23/18 05:28 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
It takes so little effort to remove a brush or 2, then 3 screws, then take apart and then press pulley onto shaft. Or block of wood under rear of shaft, then whack pulley on with hammer and soft block if you have to. Those rear bearings are not the most solid of units.
Re: Installing Alternator pulley's [Re: buildanother] #2526020
07/23/18 07:46 PM
07/23/18 07:46 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
"Take apart" is the operative phrase.
Re: Installing Alternator pulley's [Re: sixpackman] #2526183
07/24/18 12:34 AM
07/24/18 12:34 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
RR i agree never saw one with threads.IIRC my service manuals also show splitting the case.Rocky
Chrysler Firepower
Re: Installing Alternator pulley's [Re: sixpackman] #2526267
07/24/18 08:43 AM
07/24/18 08:43 AM
Michigan, USA
Michigan, USA
Thanks everyone!! Just hate to pull apart a fully restored ALT. but I guess it's not that big of a deal.
Thanks again, Appreciate all your help!!!!
Re: Installing Alternator pulley's [Re: sixpackman] #2526370
07/24/18 01:15 PM
07/24/18 01:15 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Some folks here have claimed that heating the pulley in the oven will allow it to drop right on the shaft......never worked for me.
Re: Installing Alternator pulley's [Re: sixpackman] #2527157
07/25/18 11:58 PM
07/25/18 11:58 PM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
I've heated dozens and dropped them on, no big deal.
