Z-bar bearing halves- interchange? #2525403
07/22/18 04:31 PM
07/22/18 04:31 PM
State, country, etc.
gss Offline OP
gss  Offline OP
Does anyone know if there is a commonly available later model set of bearing halves that interchanges with my 71 Charger? Hoping to get this in today so would like to avoid ordering a part. Thanks
Re: Z-bar bearing halves- interchange? [Re: gss] #2525488
07/22/18 06:58 PM
07/22/18 06:58 PM
Chicago
PurpleBeeper Offline
Chicago
Not that I know of, sorry.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Z-bar bearing halves- interchange? [Re: gss] #2525530
07/22/18 08:09 PM
07/22/18 08:09 PM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
funny... I cant find valve cover gaskets for my big block today but I have at least half dozen of those around....It just goes to show you its always sumthin
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: Z-bar bearing halves- interchange? [Re: gss] #2525535
07/22/18 08:24 PM
07/22/18 08:24 PM
md
mopars4ever Offline
mopars4ever  Offline
md
You could try a dodge dealer. Pretty sure they are still available. 2265938 part number. They could search other dealers in your area too. Probably closed today though.
Re: Z-bar bearing halves- interchange? [Re: gss] #2525700
07/23/18 02:25 AM
07/23/18 02:25 AM
gss Offline OP
gss  Offline OP
I ended up ordering the kit from Dante's.
I'm surprised there isn't a zerk in the z-bar. Any reason why I wouldn't put one in?
Re: Z-bar bearing halves- interchange? [Re: gss] #2525713
07/23/18 03:06 AM
07/23/18 03:06 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Some applications had a zerk. I think truck.
Re: Z-bar bearing halves- interchange? [Re: gss] #2525874
07/23/18 02:48 PM
07/23/18 02:48 PM
If you get the metal ones do the fitting, if plastic, like most of them, don't add grease tsk It holds dirt and moisture and adds wear to the plastic halfs. work twocents
Re: Z-bar bearing halves- interchange? [Re: gss] #2526102
07/23/18 10:02 PM
07/23/18 10:02 PM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
Disk brake pin grease is ok for rubber and plastic. It also won't collect grease.
