Exhaust Tip Alignment #2524793
07/20/18 11:18 PM
07/20/18 11:18 PM
Usa
A39Coronet Offline OP
Usa
Setting up new exhaust and oval tips on 70 roadrunner...any idea how far off bumper exhaust tip edge should be positioned? I can eye ball it, but prefer a rough estimate. All the way in against the bracket doesn't seem correct.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Exhaust Tip Alignment [Re: A39Coronet] #2525501
07/22/18 07:16 PM
07/22/18 07:16 PM
North Dakota
6PakBee Online content
6PakBee  Online Content
North Dakota
I'm no expert on '70's but doesn't the hanger set the vertical distance between the tip and the bumper?
Re: Exhaust Tip Alignment [Re: A39Coronet] #2525513
07/22/18 07:34 PM
07/22/18 07:34 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Here is mine, probably not more than 1/2".
Re: Exhaust Tip Alignment [Re: 6PakBee] #2525580
07/22/18 10:03 PM
07/22/18 10:03 PM
Cold Spring, NY
1970GTX Offline
1970GTX  Offline
Cold Spring, NY
This is correct.
Tighten the hanger.
Push the tip all the way in until the L bracket on the tip bottoms out.
Clamp the pipe.
Re: Exhaust Tip Alignment [Re: A39Coronet] #2525738
07/23/18 08:29 AM
07/23/18 08:29 AM
Usa
Usa
Thanks all...wasn't sure if it was that easy or if they needed to be pull out a bit. Normally on this car, if it's too easy, I did something wrong.
