dash lighting bullet connector size
#2525374
07/22/18 03:13 PM
07/22/18 03:13 PM
Posts: 1,894 Spahn Ranch
RMCHRGR
Spahn Ranch
Does anyone know what size these bullet connectors are? I believe they are odd size, maybe .163? In general, I find them in dash/auxiliary lighting harnesses. I seem to be having trouble finding an exact match at hardware or auto parts stores. Looked on Waytek/Del City etc. but found nothing Chrysler specific. Thanks for any suggestions.
'71 Duster '72 Challenger '17 Ram 1500
Re: dash lighting bullet connector size
[Re: RMCHRGR]
#2525452
07/22/18 05:57 PM
07/22/18 05:57 PM
Posts: 1,318 Ohio
jlatessa
Ohio
The bullet connectors included in the Painless kit are: male, .155 o.d., female, .150. i.d.
I've used them in a previous build with good results. Where they source them, ???
Did you try McMaster-Carr??
Joe
Just looked at them under a magnifier, they have the initials K.S.
[Re: RMCHRGR]
#2525569
07/22/18 09:46 PM
07/22/18 09:46 PM
RMCHRGR
Spahn Ranch
Thanks.
What I am trying to do is utilize the orange, 3 pin molded connector in the dash aux. light harness to plug in some gauge lights. I took the ashtray out and put a two hole gauge panel in its place, fits perfect and didn't have to drill any new holes. The ashtray laamp actually plugs into the 3 pin molded connector which is now empty.
So if I can find the correct size connector then I don't have to splice into the light harness, I can just run the gauge light feeds right to the existing connector.
I could cut the ashtray light wire to use the connector but I don't like cutting original stuff if I don't have to.
[Re: RMCHRGR]
#2525871
07/23/18 02:44 PM
07/23/18 02:44 PM
RMCHRGR
Spahn Ranch
I do have some junk harnesses around, guess I can look through them.
Also, good idea on the extra solder and file method, never thought of doing it that way, thanks.
Still, for future reference, I would like to know the correct size of these things.
