68 GTX Numbers #2524958
07/21/18 01:00 PM
07/21/18 01:00 PM
Ohio
70BIRD Offline OP
70BIRD  Offline OP
Ohio
Hi all,
I'm going to look at a 68 GTX today, supposed to be an original 4 speed car but needs complete resto. As far as confirming if its a numbers matching car I believe on the body need to look at the fender tag, window tag, door sticker (if any) number on radiator core support and trunk lip.
What I'm not exactly sure about are where are the numbers located on the drive train?
Thanks for any help
Re: 68 GTX Numbers [Re: 70BIRD] #2524964
07/21/18 01:09 PM
07/21/18 01:09 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
stamped in the block near the oil pressure sending unit
Not sure about the 4 spd trans
Re: 68 GTX Numbers [Re: gtx6970] #2524988
07/21/18 02:07 PM
07/21/18 02:07 PM
Ohio
70BIRD Offline OP
70BIRD  Offline OP
Ohio
Thanks Bill, how you doing?
Re: 68 GTX Numbers [Re: 70BIRD] #2525031
07/21/18 05:18 PM
07/21/18 05:18 PM
It's a dry heat
It's a dry heat
Pm sent
Re: 68 GTX Numbers [Re: 70BIRD] #2525036
07/21/18 05:34 PM
07/21/18 05:34 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
4-speed will be marked on the passenger side of the case.
Re: 68 GTX Numbers [Re: 70BIRD] #2525206
07/22/18 02:20 AM
07/22/18 02:20 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Remember that 68s are unique
The Body numbers are the SO number and will match the fender tag and broadcast sheet and window sticker.
The VIN number will match the broadcast sheet and window sticker.
Good luck up
Re: 68 GTX Numbers [Re: Alaskan_TA] #2525279
07/22/18 12:01 PM
07/22/18 12:01 PM
It's a dry heat
It's a dry heat
So same as 69 and later.
But is it the vin like later, or is it the so number
Re: 68 GTX Numbers [Re: 70BIRD] #2525326
07/22/18 01:40 PM
07/22/18 01:40 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
VIN
Re: 68 GTX Numbers [Re: 70BIRD] #2525407
07/22/18 04:34 PM
07/22/18 04:34 PM
Ohio
70BIRD Offline OP
70BIRD  Offline OP
Ohio
I went to check the car out and it turns out it's a console automatic. Didn't check the numbers on the trans as it was in an enclosed trailer but the numbers I checked on engine, tag, VIN plate matched and he had the build sheet as well. Unfortunately there was a lot rust on the car, the floor pan, trunk, rear frame rails all in bad shape. The pass side torsion bar crossmember had a hole big enough to fit my hand through and someone replaced the rear quarter panels at some point but not a very good job.
Re: 68 GTX Numbers [Re: 70BIRD] #2526535
07/24/18 06:44 PM
07/24/18 06:44 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If you saw the VIN stamped on the engine then you would have seen it on the trans too ... if it were the original trans ... it's stamped on the bellhousing flange right above the engine number at the same time after the 2 assemblies are bolted together.
Re: 68 GTX Numbers [Re: JohnRR] #2526671
07/24/18 11:46 PM
07/24/18 11:46 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
'68 performance automatics would be stamped similar to this scope
Re: 68 GTX Numbers [Re: 6bblgt] #2526797
07/25/18 11:10 AM
07/25/18 11:10 AM
Ohio
70BIRD Offline OP
70BIRD  Offline OP
Ohio
Thanks for the pic, did not see a number like that stamped on trans.
Re: 68 GTX Numbers [Re: 70BIRD] #2526801
07/25/18 11:24 AM
07/25/18 11:24 AM
New York
rarefish Offline
rarefish  Offline
New York
Just remember the VIN sequence number will Not appear on the fender tag that is under the hood.
