Dakota inner tie rod #2525306
07/22/18 12:57 PM
07/22/18 12:57 PM
n.e. pa.
65rbdodge Offline OP
n.e. pa.
I’m changing the inner tie rod on an 88 Dakota 2wd. It looks like the part that screws into the rack has been swaged for lack of a better term in place. I’m guessing I need to cut this part off to spin the tie rod off? I don’t see a nut to put a wrench on like the new one has?
Re: Dakota inner tie rod [Re: 65rbdodge] #2525370
07/22/18 03:05 PM
07/22/18 03:05 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You could try a "How to" search online and see if there is a video for it. There are vids that cover most everything.
Re: Dakota inner tie rod [Re: 65rbdodge] #2525442
07/22/18 05:37 PM
07/22/18 05:37 PM
n.e. pa.
n.e. pa.
I got it, ground the peen off and used some big channel locks
Re: Dakota inner tie rod [Re: 65rbdodge] #2528642
07/29/18 03:30 PM
07/29/18 03:30 PM
elmira ny
hp340nos Offline
hp340nos  Offline
elmira ny
is your rack a power rack or manual?
Re: Dakota inner tie rod [Re: 65rbdodge] #2528799
07/29/18 10:17 PM
07/29/18 10:17 PM
n.e. pa.
n.e. pa.
Manual
Re: Dakota inner tie rod [Re: 65rbdodge] #2530610
08/02/18 07:08 PM
08/02/18 07:08 PM
elmira ny
hp340nos Offline
hp340nos  Offline
elmira ny
where did buy the inner tie rod ends.ii need to change the ones on my 88 also.thanks
Re: Dakota inner tie rod [Re: 65rbdodge] #2531674
08/04/18 10:57 PM
08/04/18 10:57 PM
n.e. pa.
n.e. pa.
Rock auto
Re: Dakota inner tie rod [Re: 65rbdodge] #2544615
09/02/18 01:30 PM
09/02/18 01:30 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I used a large crows foot at work for all I did.Even the ones with a rivet came off.Some are just peened when they are installed.Always use locktite when installing.They do make a tool for them.Has different sizes that you put in the tube. Rocky
Chrysler Firepower
