Loading up and slight miss #2525037
07/21/18 05:40 PM
07/21/18 05:40 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
I am getting a load up type feel on my car and feels like a miss at idle and putting around in second gear. When I get on the loud peddle it smooths out and get to business. I went through and did plugs (gap at 40) new MSD wires new cap new rotor new pickup in distributer. lashed the valves at .020 cold(per Indy). As some may remember I have the Fast ez efi system. it ran great last summer now its a pile of poop.
Can a bad voltage regulator cause this?? that's about all I haven't replace.
be gentle I am ready to burn the car to the ground at this point.
Thank you
Kiddart
Re: Loading up and slight miss [Re: Kiddart] #2525043
07/21/18 05:48 PM
07/21/18 05:48 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
Not an expert by any definition,,but how much fuel have you gone thru with this issue?
Funky load of pump gas,,it happens.???
Maybe some strong injector /fuel treatment might yield something.
Possibly temp. sensor issue. EFI thinks engine is cold/enrichment too??
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Loading up and slight miss [Re: Kiddart] #2525047
07/21/18 05:59 PM
07/21/18 05:59 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
I haven't gone thru to much fuel, the issue starts as soon as I crank it up within 5 seconds or so. I should try some injector cleaner as well
Thank you
Kiddart
Re: Loading up and slight miss [Re: Kiddart] #2525260
07/22/18 11:23 AM
07/22/18 11:23 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
how about a new O2 sensor?
Re: Loading up and slight miss [Re: Kiddart] #2525263
07/22/18 11:33 AM
07/22/18 11:33 AM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
Check the Valve Springs.... Mite have went bad from sitting..
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: Loading up and slight miss [Re: Kiddart] #2525281
07/22/18 12:05 PM
07/22/18 12:05 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
Racerhog, heads were just freshened at Modern cylinder head over the winter.
B1maxx I can check the O2 but not getting a error code?
Thank you
Kiddart
Re: Loading up and slight miss [Re: Kiddart] #2525289
07/22/18 12:25 PM
07/22/18 12:25 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
What fuel have you been running? Did it sit all winter in the tank? My geuss is dirty injectors, especially if you were running pump fuel with ethanol in it.
Re: Loading up and slight miss [Re: Kiddart] #2525472
07/22/18 06:27 PM
07/22/18 06:27 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
I run the Turbo Blue from the pump, but didn't leave any in over the winter. I will get some injector cleaner and see what happens
Thank you
Kiddart
Re: Loading up and slight miss [Re: Kiddart] #2525865
07/23/18 02:28 PM
07/23/18 02:28 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
O2 could be buggered up, sending info, just wrong feedback.
Re: Loading up and slight miss [Re: Kiddart] #2526315
07/24/18 11:51 AM
07/24/18 11:51 AM
K
Kiddart Offline OP
Kiddart  Offline OP
K
Here is my course of action as of today.
1. I am taking out the injectors and have my son clean them and test them at school next week
2. Going to test and or replace O2 Sensor after the injectors are cleaned
3. New Plugs AGAIN before I restart it.
Not sure when all this will take place because I am nursing a rib injury and have my daughters grad party this weekend. I know its Monster Mopar at Norwalk, my wife didn't clear the date with me before planning the party. LOL
Its to hot to race anyways.
keep the comments and thoughts coming.
Thank you
Kiddart
Re: Loading up and slight miss [Re: Kiddart] #2530946
08/03/18 01:29 PM
08/03/18 01:29 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
B1MAXX, Looks like its the o2, pulled it last night and its in really bad shape completely loaded up with carbon. I was playing with the AF settings and it wasn't taking any thing, I ordered a new one this morning from Jegs. See what happens when its gets here.
Thank you
Kiddart
