Squat or Lift ? #2525127
07/21/18 11:24 PM
07/21/18 11:24 PM
Australia
O
ozymaxwedge Offline OP
O
Australia
As the title says guys. Should your car (mopar streeter) squat or lift the rear on a launch ?
Ive been told both are what you want by different drag racers.
Older video of my car on ET street radials, spring leaf, basic comp eng shocks and caltrac. Car has gone 10.1 since this but still launches the same and has bad 60' times from 1.5-1.7
15 second and 21 second frame show lift.
3750 lb with me in it.
Going to a street meet soon and would love to PB the car.
Can Caltrac adjustment control squat / lift or is it all in the spring/shock ?
https://www.youtube.com/watch?v=cb9FbDUWBLQ
1963 Plymouth Max Wedge
1971 Barracuda
Re: Squat or Lift ? [Re: ozymaxwedge] #2525128
07/21/18 11:28 PM
07/21/18 11:28 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Lift, absolutely. How much depends on how fast you are, but with your perimeters, Lift.
Re: Squat or Lift ? [Re: ozymaxwedge] #2525136
07/21/18 11:48 PM
07/21/18 11:48 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
you should get some separation, but it really looks like you need more control. At a minimum some Rancho/Calvert SA shocks, or even some DA units to help control the rear. It seems as if the car jumps up unloading the tire...
It looks like you are running drag radials? Radials need very good prep and either dead hook or go up in smoke. Bias plies are more forgiving for poor track prep and/or poor chassis tune-up
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Squat or Lift ? [Re: ozymaxwedge] #2525143
07/22/18 12:00 AM
07/22/18 12:00 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Ozy I love that car and that video!
I think you'd love the M/T 275 Pro, I ran some used ones down the track last year and it dead hooked every time. I only run 10.60's though. My suspension is bone stock, added one leaf to the factory springs, 60 foot is 1.51 with highway gears in it. I love those tires. I have a set of Nittos to try this year but I doubt they'll hook as good.
Re: Squat or Lift ? [Re: ozymaxwedge] #2525147
07/22/18 12:04 AM
07/22/18 12:04 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Lift aids tire load, squat removes load. Once the power levels get huge, (way more than I'll ever have) the tire can get over worked. In that case the instant center will be low and long enabling squat to keep from over working the tire.
Doug
Re: Squat or Lift ? [Re: ozymaxwedge] #2525150
07/22/18 12:13 AM
07/22/18 12:13 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
It's separating mighty hard. I would think a better shock that's able to control it would help. Also pay attention to shock installed and extended length. It maybe topping the shock which effective jerks up on the housing and unloads the tire.
Re: Squat or Lift ? [Re: ozymaxwedge] #2525155
07/22/18 12:25 AM
07/22/18 12:25 AM
Australia
O
O
Australia
OK thanks guys, I'll look at shocks now. Cheers ProSport, I do have some 275/60 radial pro's on it now.
1971 Barracuda
Re: Squat or Lift ? [Re: OUTLAWD] #2525172
07/22/18 01:09 AM
07/22/18 01:09 AM
Originally Posted By OUTLAWD
you should get some separation, but it really looks like you need more control. At a minimum some Rancho/Calvert SA shocks, or even some DA units to help control the rear. It seems as if the car jumps up unloading the tire... iagree tsk
iagree scope thumbs
Hopefully the next vid will show you carrying the front tires from the kit to around the 60 Ft. lights thumbs
Re: Squat or Lift ? [Re: ozymaxwedge] #2525181
07/22/18 01:24 AM
07/22/18 01:24 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Something more than Rancho singles to control extension
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Squat or Lift ? [Re: ozymaxwedge] #2525195
07/22/18 01:47 AM
07/22/18 01:47 AM
Australia
O
O
Australia
These ??
https://www.ebay.com.au/itm/CALVERT-RACING-CR22142-REAR-DRAG-RACING-SHOCKS-9-WAY-ADJUSTABLE-SUIT-CHRYSLER/142759347689?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
1971 Barracuda
Re: Squat or Lift ? [Re: ozymaxwedge] #2525199
07/22/18 02:09 AM
07/22/18 02:09 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I went a 1.33 on old 5 way Ranchos and M/T 28.10.5's but now run Viking da's and went a 1.34 on Hoosier QTP street tires.......... thumbs
Re: Squat or Lift ? [Re: ozymaxwedge] #2525209
07/22/18 02:26 AM
07/22/18 02:26 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Originally Posted By ozymaxwedge
These ??
I gave up on those a couple of years ago . I know some still use them at higher hp levels , once i hit 10s they lost control of extension . They are now on the shelf .
Like others , i have gone Viking DA . I ordered the radial valved units . Very happy .
Tex
New best MPH 130.32
Re: Squat or Lift ? [Re: ozymaxwedge] #2525275
07/22/18 11:57 AM
07/22/18 11:57 AM
gregsdart Online content
gregsdart  Online Content
Yep! Much better control needed on the rear for starters. Buy more shock than you need, so you don't have to buy another set. I am on my second set (stiffer) of GOOD double adjustables. I had to go to BIG GUN Afcos to control my deal
Re: Squat or Lift ? [Re: ozymaxwedge] #2525362
07/22/18 02:49 PM
07/22/18 02:49 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I can offer that my Calvert setup performs a lot better with the Calvert shocks than it did with cheap C/E shocks. The tighter I adjusted the shocks, the quicker the car went, and the less rise it had. I run my setup at full stiff on the shocks and 2 flats of preload in the bars, and it barely rises at all; the rear bumper actually moves downward as the front end comes up. The axle separates slightly as it plants the tire. My car isn’t real fast, but it leaves pretty good for a 3875lb, 11.40 car. It typically 60’s in 1.58 and will put a little daylight under both front tires.
Re: Squat or Lift ? [Re: ozymaxwedge] #2525648
07/23/18 12:03 AM
07/23/18 12:03 AM
Australia
O
O
Australia
Just purchased Viking DA smile
1971 Barracuda
Re: Squat or Lift ? [Re: ozymaxwedge] #2525653
07/23/18 12:17 AM
07/23/18 12:17 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
this is what you want grin
Tex
New best MPH 130.32
Re: Squat or Lift ? [Re: tex013] #2525670
07/23/18 12:44 AM
07/23/18 12:44 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Below is the difference between SS 3400 lbs. springs and Cal-Tracs with split mono's.
Both worked, up to a point, but two completely different pre-loads on the torsion bars and all twisted up with SS springs.
'63 Dodge 330
11.19 @ 121 mph
Re: Squat or Lift ? [Re: ozymaxwedge] #2525688
07/23/18 01:15 AM
07/23/18 01:15 AM
Australia
O
O
Australia
Nice you two ^^^^^
1971 Barracuda
Re: Squat or Lift ? [Re: ozymaxwedge] #2525725
07/23/18 06:40 AM
07/23/18 06:40 AM
UK
rb446 Offline
rb446  Offline
UK
And this is old school on my 340 with stock 340 l/springs clamped@front, std performance shocks with 2" extensions and the dreaded pinion snubber. It comes up straight, reason pass tyre is not off ground is because I didn't know the bump stop had fell off, I also had longer spring hangers on the car and they moved inward on the hit around 6", like a modern day slider....and yes its killing the tyre somewhat...SS springs can also be made to work with even lift with good dble adj. shocks....don't have to have caltracs although they are good.
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: Squat or Lift ? [Re: rb446] #2525727
07/23/18 07:23 AM
07/23/18 07:23 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
The Calvert 9 way adjustable shocks are Rancho's with Calvert stickers on them.
Alan Jones
