Page 2 of 5 1 2 3 4 5
Re: These plugs too cold? [Re: jbc426] #2518431
07/06/18 02:51 PM
07/06/18 02:51 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I built the carb and he has a WB...........
Re: These plugs too cold? [Re: jbc426] #2518622
07/06/18 11:17 PM
07/06/18 11:17 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Yep. I have and use a wide band. Cruises 13.8 to 14.2. Im still not convinced to carb is rich. I will run some 7's in it awhile and see how they burn. I have some 6's on order as well.
Re: These plugs too cold? [Re: mopar dave] #2523962
07/19/18 09:56 AM
07/19/18 09:56 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Any results,changes?I am looking at going to a hotter plug NGK R5671A-8[4554] from a -9.
Re: These plugs too cold? [Re: mopar dave] #2524045
07/19/18 12:44 PM
07/19/18 12:44 PM
Deep DEEP SOUTH
LAD 524 Online content
LAD 524  Online Content
Deep DEEP SOUTH
Dave at 3K rpm cruise you should be on the mains....first Id go to NGK6 and see an, then I'd pull a little jet for better AFR, even the best carbs need dialing into your combo.
Running it at cruise in the hi 14s, lo 15s aint gonna hurt it and will clean it up, there is very little load on the engine at idle or cruise.
I run my Hemi in this way on NGK 6s - plugs look perfect withe a nice ring on the plg base/shell and the car runs clean/awesome. WOTs are in the mid 12s. Imho, NGK 8s are a little cold for the street generally, it really depends on your combo etc. Im gonna switch to 8s for the track.
The engine is telling you what it likes...let er have what she needs wink
Re: These plugs too cold? [Re: LAD 524] #2524302
07/19/18 11:38 PM
07/19/18 11:38 PM
Mt Morris Michigan
Mt Morris Michigan
Using ngk 7's now. 3000 cruise rpm afr is 13.0 now. 3500 cruise gives 12.5 range. Not sure when boosters are all in. I believe the boosters start just after 2500rpm. Plug rings have a little color, but porcilen still dark. What causes plugring to burn clean but porcilen to burn dark?
Re: These plugs too cold? [Re: mopar dave] #2524322
07/20/18 12:32 AM
07/20/18 12:32 AM
crabman173
crabman173
Man i run 8's in a 13.7:1 alky engine and they are almost too cold for that
Re: These plugs too cold? [Re: mopar dave] #2524373
07/20/18 03:30 AM
07/20/18 03:30 AM
If I was you I would lean down the idle fuel feed circuit and the transfer fuel feed circuits to cruise north of 14.8 AFR up scope
My old pump gas Duster was tuned to do that with the six pack and the Holley 1050 CFM Dominator later, lean is mean and responsive also boogie scope twocents
Re: These plugs too cold? [Re: mopar dave] #2524420
07/20/18 10:24 AM
07/20/18 10:24 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Now you can at least read the plug to see what is going on with any changes.Thank you for your info.
Re: These plugs too cold? [Re: Cab_Burge] #2524440
07/20/18 11:07 AM
07/20/18 11:07 AM
Mt Morris Michigan
Mt Morris Michigan
I resently changed the t slot to a .059 from a .055. Engine sounds smoother and runs cooler. I seem to have a pump gas issue and i think it might be the ethanol boiling in the squirter circuit on a hot air temp day. Cool engine and cool air temp if goes away. I can watch the fuel spurt out of pri squirter at idle with hot engine and air temp. Switched brand of fuel and got worse.
Re: These plugs too cold? [Re: mopar dave] #2524631
07/20/18 05:00 PM
07/20/18 05:00 PM
Washington
madscientist Offline
Washington
Are you saying the fuel is percolating out of the squirters or is fuel being pulled through the squirter?
I remember someone on here posted a link to a company that made an anti pullover parts to stop the squirter from letting fuel get by it from airflow.
Re: These plugs too cold? [Re: madscientist] #2524643
07/20/18 05:19 PM
07/20/18 05:19 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
Another thing that I heard helps is to not use the tube style squirters.....
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: These plugs too cold? [Re: madscientist] #2524697
07/20/18 07:41 PM
07/20/18 07:41 PM
Mt Morris Michigan
Mt Morris Michigan
Its always idling when it does this. next time i will shut it off and see what happens.
Re: These plugs too cold? [Re: mopar dave] #2524801
07/20/18 11:44 PM
07/20/18 11:44 PM
Does it have the correct check valve, anti siphoning ball, under the squirter? scope
if not, get one first and see if that helps scope
The first 4 barrel I "rebuilt, dipped and kitted,(1957 Chevy Rochester 4GC) ended up with me not knowing where that check ball went whiney
Stuff happens shruggy
Re: These plugs too cold? [Re: Cab_Burge] #2524806
07/20/18 11:52 PM
07/20/18 11:52 PM
Mt Morris Michigan
Mt Morris Michigan
Yes. It does have the check valve. I still think its the fuel. My brother inlaw has same issue with a edelbrock carb.
Re: These plugs too cold? [Re: mopar dave] #2524809
07/20/18 11:59 PM
07/20/18 11:59 PM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
I run NGK 8s in my small block 11 to 1 pump gas drag week motor. Usually do the week on only two sets. The street drives dirty them up a little, but the nitrous passes clean them right up!!
When I ran it NA, I had 7s in it all week, and they were perfect.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: These plugs too cold? [Re: mopar dave] #2524967
07/21/18 01:16 PM
07/21/18 01:16 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Maybe you can find someone with a fuel gravity test kit I don't know what other things you can check.Will you try a new gas station/brand?I got some #7 plugs to use and your info was helpful in choosing the plugs.
Re: These plugs too cold? [Re: Cab_Burge] #2524993
07/21/18 02:23 PM
07/21/18 02:23 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
No ball bearings that's old skool it has weighted check valves............
Re: These plugs too cold? [Re: Thumperdart] #2525006
07/21/18 02:58 PM
07/21/18 02:58 PM
We have learned a lot since then, huh whistling
As far as sucking fuel out of the squirters that is usually a sign that the carb. is NOT idling on the idle circuit only, it may be idling up on the transfer slots shruggy work
Re: These plugs too cold? [Re: Cab_Burge] #2525017
07/21/18 04:16 PM
07/21/18 04:16 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Shouldn't pull fuel at idle at all but up top under power, actually part of the tune up just check out Shiloh's video of his motor on the dyno.......... thumbs
Re: These plugs too cold? [Re: mopar dave] #2525486
07/22/18 06:55 PM
07/22/18 06:55 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
What is the idle AFR?
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
