can a '67 440 Chrysler "300" have an AVS? UPDATE! #2524566
07/20/18 02:58 PM
07/20/18 02:58 PM
RapidRobert Offline OP
Such as a very late model year build? I was not dressed to do any numbers checking/digging but I did see the AVS air door when he pulled the air cleaner to prime it. Thank you for your time
Re: can a '67 440 Chrysler "300" have an AVS? [Re: RapidRobert] #2524570
07/20/18 03:02 PM
07/20/18 03:02 PM
dogdays Offline
dogdays  Offline
It's a Mopar, never say never.
R.
Re: can a '67 440 Chrysler "300" have an AVS? [Re: dogdays] #2524583
07/20/18 03:22 PM
07/20/18 03:22 PM
Alright
Re: can a '67 440 Chrysler "300" have an AVS? [Re: RapidRobert] #2524638
07/20/18 05:11 PM
07/20/18 05:11 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i don't think so. the avs was a smog era carb and model year 1967 didn't have to meet those standards. all the '67 440's I know of had afb's. there were some 440's with small holleys but i'm not sure which year they were.
Re: can a '67 440 Chrysler "300" have an AVS? [Re: RapidRobert] #2524650
07/20/18 05:34 PM
07/20/18 05:34 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
67 was AFB only, If it had an AVS it was almost certainly swapped. Sure, never say never, but in this case I'll say it until someone can prove otherwise without any doubt.
.02
Re: can a '67 440 Chrysler "300" have an AVS? [Re: RapidRobert] #2524684
07/20/18 07:20 PM
07/20/18 07:20 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Just check the number stamped on the base, or if it has a tag under the lid bolt. That will tell everything
Re: can a '67 440 Chrysler "300" have an AVS? [Re: cudaman1969] #2524783
07/20/18 10:18 PM
07/20/18 10:18 PM
The guy says he "knows" it is a 440 & it has at first glance that grungy "original/untouched" look as does the AVS & it has a yellow vac cap on the bowl vent for the hose to the charcoal canister that a 68 car would have. I will check numbers the next time I get over there but the guy says he really doesn't want to come off of it (I may have to put some hundreds in my pocket!). & it is a 2 dr. Thanks guys.
Re: can a '67 440 Chrysler "300" have an AVS? [Re: RapidRobert] #2524804
07/20/18 11:47 PM
07/20/18 11:47 PM
fredericksburg,va
fredericksburg,va
Vacuum cap? No way
Re: can a '67 440 Chrysler "300" have an AVS? [Re: RapidRobert] #2524816
07/21/18 12:25 AM
07/21/18 12:25 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
1970 first year for that, IIRC. 2ยข
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: can a '67 440 Chrysler "300" have an AVS? [Re: 3hundred] #2524828
07/21/18 12:51 AM
07/21/18 12:51 AM
Oh OK '70 is the first year for the canister? Yeah I gotta get some numbers. Yes the vac cap has been added. It ran (barely).
Re: can a '67 440 Chrysler "300" have an AVS? [Re: RapidRobert] #2524833
07/21/18 01:00 AM
07/21/18 01:00 AM
fredericksburg,va
fredericksburg,va
After all those years, carb went bad and replaced it with a newer one, simple. In 68 years I have a few things replaced on me too.
Re: can a '67 440 Chrysler "300" have an AVS? [Re: cudaman1969] #2524840
07/21/18 01:38 AM
07/21/18 01:38 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
But an AVS doesn't fit where an AFB has been
Re: can a '67 440 Chrysler "300" have an AVS? [Re: Morty426] #2524849
07/21/18 02:23 AM
07/21/18 02:23 AM
at first glance the only thing that looked off was the AVS (with the bright yellow vac cap!) & if I am reading the responses right that a 67 car (even a late build) could (should?) not have an AVS (which AFAIK is a 68 to mid 71 emissions carb) then all that is left is for me to go back over there in my grubbies & do some digging & get some numbers. (eng number/letter on machined pad by dist/carb #) Thanks guys.
Re: can a '67 440 Chrysler "300" have an AVS? [Re: Morty426] #2524852
07/21/18 02:30 AM
07/21/18 02:30 AM
Morty are you saying an AVS will not bolt on an OE AFB manifold?
Re: can a '67 440 Chrysler "300" have an AVS? [Re: RapidRobert] #2524872
07/21/18 05:45 AM
07/21/18 05:45 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I thought the AFB had a smaller bolt pattern. I have only owned 1 AFB 4 barrel intake and it looks way smaller to me than the AVS manifolds I have
Re: can a '67 440 Chrysler "300" have an AVS? [Re: RapidRobert] #2524894
07/21/18 09:59 AM
07/21/18 09:59 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
there's small bolt pattern afb's and large pattern. isn't a '67 magnum intake the same as a '68? were the '66 and down intakes used in '67?
Re: can a '67 440 Chrysler "300" have an AVS? [Re: lewtot184] #2524910
07/21/18 11:16 AM
07/21/18 11:16 AM
it did not have the good HP ex manifolds (so its a 350 horse I am assuming) if that helps.
Re: can a '67 440 Chrysler "300" have an AVS? [Re: RapidRobert] #2525002
07/21/18 02:52 PM
07/21/18 02:52 PM
Missouri
randavis Offline
randavis  Offline
Missouri
I don't know about a 67, but according to the 68 fsm and also this rebuild kit instruction sheet say an AVS was used in 68 on 383's and 440's.
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI.
New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
Re: can a '67 440 Chrysler "300" have an AVS? [Re: randavis] #2525005
07/21/18 02:58 PM
07/21/18 02:58 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
I'll have to go with what Mr. Smith said,no exception !! grin
Re: can a '67 440 Chrysler "300" have an AVS? [Re: 62maxwgn] #2525025
07/21/18 04:38 PM
07/21/18 04:38 PM
After all the love I got on this one, I will get over there when I can.
