Which rad cap #2524731
07/20/18 08:29 PM
07/20/18 08:29 PM
ohio
dragon Offline OP
dragon  Offline OP
ohio
How are you deciding what pressure cap to run on your radiator Thanks
Re: Which rad cap [Re: dragon] #2524752
07/20/18 09:17 PM
07/20/18 09:17 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
18-21 psi, got to keep the coolant in the radiator.
Re: Which rad cap [Re: nss guy] #2524762
07/20/18 09:41 PM
07/20/18 09:41 PM
IN
ahy Offline
ahy  Offline
IN
From memory, 12 or 14 psi was original and some replacements are 16 psi. With a good cooling system + antifreeze, either should work fine. Boiling point with 50/50 is above 250 F with 12 psi.
Only thing to add is sometimes the "flip top" type with pressure release lever tend to leak. I avoid those. Otherwise I find a decent replacement cap from the AP store is fully functional.
If you want original appearance, need to look around.
