You are better off repairing the line with steel instead of rubber as gtx6970 said. However there are rubber hoses on transmission cooler lines from the factory. If you cut out the bad part. Flare the ends a little (I use a double flaring tool but just lightly flare the line with the bubble) and use hose designed for transmission fluids it would be fine.
