68 D100 Uteline bed mount wooden spacers?? #2524551
07/20/18 02:41 PM
07/20/18 02:41 PM
Blairsden, CA
Triggerfish Offline OP
Blairsden, CA
Can anyone post a photo of where the wooden & rubber Uteline bed to frame spacers go so I can mount my newly painted bed on my frame? My D100 was originally a 383 Sweptline that the 2nd owner sold the beautiful bed & replaced it with a Uteline bed. So, I only found one wooden spacer when we removed it & got the correct rubber mount spacers but need to get or make wooden ones. Thanks in advance!...
68 D100 ready to get lowered.JPGD110 new bed small file.jpgD100 restored frame & 383.jpg
Re: 68 D100 Uteline bed mount wooden spacers?? [Re: Triggerfish] #2524560
07/20/18 02:54 PM
07/20/18 02:54 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Are you sure about the wooden spacers? That doesn't seem like some thing the factory would do.
Re: 68 D100 Uteline bed mount wooden spacers?? [Re: stumpy] #2524584
07/20/18 03:22 PM
07/20/18 03:22 PM
Blairsden, CA
Blairsden, CA
I know my 71 W100 Swepty 4x4 has wooden spacers & I found one in the box of uteline bed parts & a google search brought up swepline.org posts that described uteline wood spacer sizes, etc. I bought the reopop rubber cab & bed mount spacers, but wonder if the wooden one applies.
Re: 68 D100 Uteline bed mount wooden spacers?? [Re: stumpy] #2524818
07/21/18 12:30 AM
07/21/18 12:30 AM
Blairsden, CA
Blairsden, CA
Turns out you're partially right. Utelines had no wooden spacers. Only the Sweptline beds had them. I got the new rubber mount kits from Easy Street LLC & they are all rubber ones for the Uteline. Looked under my 71 Swepty W100 & it has wood spacers.
Re: 68 D100 Uteline bed mount wooden spacers?? [Re: Triggerfish] #2524900
07/21/18 10:32 AM
07/21/18 10:32 AM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
To the best of my knowledge, the Utiline beds had a combination of wood (at frame mount points and at cross members) and rubber mounts. The sweptline beds used wood blocks only.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: 68 D100 Uteline bed mount wooden spacers?? [Re: Soopernaut] #2524950
07/21/18 12:45 PM
07/21/18 12:45 PM
Blairsden, CA
Blairsden, CA
I think you're 100% right & the only wood mounting blocks needed for Utelines is for the step mounting setup, & I just discovered Dodge Connection sell the one I need.
Re: 68 D100 Uteline bed mount wooden spacers?? [Re: Triggerfish] #2525012
07/21/18 03:43 PM
07/21/18 03:43 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Well I learned something new. up
Re: 68 D100 Uteline bed mount wooden spacers?? [Re: Triggerfish] #2525237
07/22/18 09:40 AM
07/22/18 09:40 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
On my LRE the rear bed crossmember required a spacer. The original was wood along with the step plates. Made mine outta nylon.
