Re: 68 D100 Uteline bed mount wooden spacers??
[Re: stumpy]
#2524818
07/21/18 12:30 AM
07/21/18 12:30 AM
Posts: 1,954 Blairsden, CA
Triggerfish
Blairsden, CA
Are you sure about the wooden spacers? That doesn't seem like some thing the factory would do. Turns out you're partially right. Utelines had no wooden spacers. Only the Sweptline beds had them. I got the new rubber mount kits from Easy Street LLC & they are all rubber ones for the Uteline. Looked under my 71 Swepty W100 & it has wood spacers.
[Re: Triggerfish]
#2524900
07/21/18 10:32 AM
07/21/18 10:32 AM
Posts: 2,682 Des Moines IA
Soopernaut
Des Moines IA
To the best of my knowledge, the Utiline beds had a combination of wood (at frame mount points and at cross members) and rubber mounts. The sweptline beds used wood blocks only.
1970 Dodge d100/eventually going on a 77 D100 frame
[Re: Soopernaut]
#2524950
07/21/18 12:45 PM
07/21/18 12:45 PM
Triggerfish
Blairsden, CA
To the best of my knowledge, the Utiline beds had a combination of wood (at frame mount points and at cross members) and rubber mounts. The sweptline beds used wood blocks only. I think you're 100% right & the only wood mounting blocks needed for Utelines is for the step mounting setup, & I just discovered Dodge Connection sell the one I need.
