2010 Challenger 5.7 Hemi w/manual trans rear end mods #2524515
07/20/18 01:30 PM
07/20/18 01:30 PM
Wheatfield, NY
Cuda340 Offline OP
Cuda340  Offline OP
Wheatfield, NY
If you bolt a set of slicks on, is it going to blow that rear apart? Stock clutch, not a slipper. Any mods need to be done? Certain type of slick to be used? Size of slicks and rims? Any info would be helpful.
Jeff
Re: 2010 Challenger 5.7 Hemi w/manual trans rear end mods [Re: Cuda340] #2524599
07/20/18 03:38 PM
07/20/18 03:38 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have a 2012 5.7L R/T Challenger Classic with a 6 Spd manual & to me the rear end does seem to be the week link. Wheels hops pretty bad also without the traction control on. I haven't broken anything but it doesn't seem to like the punishment when power shifted. I wouldn't try slicks on the stock rear without some upgrades.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 2010 Challenger 5.7 Hemi w/manual trans rear end mods [Re: Cuda340] #2524619
07/20/18 04:20 PM
07/20/18 04:20 PM
Wheatfield, NY
Cuda340 Offline OP
Cuda340  Offline OP
Wheatfield, NY
What are some stock rear upgrades that would be beneficial?
Re: 2010 Challenger 5.7 Hemi w/manual trans rear end mods [Re: Cuda340] #2524966
07/21/18 01:16 PM
07/21/18 01:16 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
I have a '17 T/A, 5.7/6-speed with the Super Track Pack, launch control, and other nonsense. You can launch it at 2500 on the street and it goes pretty well, chirps the tires through the first few gears, spins slightly at launch with the traction control off.
I took it to the local 1/8th mile a few weeks ago for shits and giggles. Despite the owner having the balls to call this place "the house of hook", the car SPUN LIKE MAD. The first pass, the launch control didn't activate, and I launched it around 4k. It wheel hopped at the launch and then unloaded the tires every time I shifted. Ran 9.8 at 81. Launching it at 2500 with thew launch control, it didn't hop, but still spun, and unloaded the tires at every shift. I eventually got the car to run 9.15 at 83, 2500 launch, shifting at 5500, no traction control.
That being said...I would not even begin to consider racing this car regularly unless I put a solid axle in it. The IRS is awesome, the car drives amazing, but scared the [censored] out of me at the track (I've been 8.70's in an Omni chassis car, FWIW). There was another guy running a new Scat Pack with Drag Radial's that day at the track...he was hopping worse than myself. I'm not real "up" in the new Challenger world...but I'm sure they have some sort of modifications for the IRS set-up. From what I have read though...people are claiming these cars are fine in stock form at the dragstrip. Supposedly better than the Mustang/Camaro. I would think someone makes a better than stock bushing to replace the OEM pieces in the rear. I think any type of regular abuse would call for such.
My personal opinion is that the launch RPM is key. I think if you could wire a two-step up to the clutch pedal to launch the car at 2-3k RPM's, you would be much further ahead as opposed to throwing money at the rear end seeking a miracle cure. Like I said about my car...at 2500 it launched smooth, at 4000...hopped like mad.
Re: 2010 Challenger 5.7 Hemi w/manual trans rear end mods [Re: Cuda340] #2524996
07/21/18 02:35 PM
07/21/18 02:35 PM
Washington
W
weedburner Offline
weedburner  Offline
W
Washington
Micah Doban @ OST Dyno was 1st first Gen 3 6spd/IRS in the 9's (2012 Challenger), he uses a ClutchTamer to soften the hit on the IRS...
Grant
Re: 2010 Challenger 5.7 Hemi w/manual trans rear end mods [Re: Cuda340] #2525101
07/21/18 08:34 PM
07/21/18 08:34 PM
ohio
bigblockrik Offline
bigblockrik  Offline
ohio
I have a 13 r/t with a arrington blower and headers i have a lot of hop also.Haven't run it yet but i am looking at replacing the bushings and control arms.Any good things about the hop not items for sale ?
Re: 2010 Challenger 5.7 Hemi w/manual trans rear end mods [Re: Cuda340] #2525182
07/22/18 01:26 AM
07/22/18 01:26 AM
Topeka Kansas
K
ksj Online content
ksj  Online Content
K
Topeka Kansas
http://modernmoparforum.com/ I have a 2012 STP 5.7 MT car and theres some good info here.
