Power steering into an A 100 #2522033
07/15/18 04:17 AM
07/15/18 04:17 AM
North America
2002bluert Offline OP
North America
Hello I was wondering if anyone has put power steering into a A 100?
Re: Power steering into an A 100 [Re: 2002bluert] #2524295
07/19/18 11:19 PM
07/19/18 11:19 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Factory had a Power assist system (think power ram on linkage, not integral box). Kind of like this FERD system
https://www.hemmings.com/magazine/hmn/2011/08/Power-Steering-Cylinders/3702381.html
I got all the pieces with one of my buys, but it's not something I want to restore and add to any of my projects. Getting someone to rebuild and finding parts would be a big issue.
The typical manual steering is designed for skinny wheels and tires at around town speeds. If you want to add P/S for wide tires, big offsets or something else past the original design, you are going to just wear out or break stuff faster. The typical newer owner wants lowering, better brakes, better steering and better suspension. If this is you, consider a complete front replacement.
No kits that I'm aware of, but I've seen fabricated Mustang II IFS in various early vans. They have a cross member very low in front to keep the geometry correct. More recent swaps include Crown Vic IFS.
Re: Power steering into an A 100 [Re: 2002bluert] #2524367
07/20/18 02:56 AM
07/20/18 02:56 AM
fredericksburg virginia
mopwrd340 Offline
mopwrd340  Offline
Some newer cars have electric p/s some hot rod builds have also used this set up who sells this stuff i don't know but worth looking into .
Re: Power steering into an A 100 [Re: 2002bluert] #2524482
07/20/18 12:19 PM
07/20/18 12:19 PM
Truck Y'all ! Offline
Somebody has come out with a kit to adapt a Toyota (I think) steering box to a pre-'72 D100. Not sure if any of those parts would help you in your quest or not.
As per RodStRace, I have walked the hot, dusty road of parts procurement, rebuild and install of a D300 power steering (assist, actually) system. It's not alot of fun. Not much benefit compared to a "real" system but it is a big improvement in a big truck.
For my A100, I just suffer along wink
Re: Power steering into an A 100 [Re: 2002bluert] #2524494
07/20/18 12:48 PM
07/20/18 12:48 PM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
CPP has a kit for Sweptline trucks. The A100/108 is different when it comes to steering because of the position of the column in relation to the axle. It uses a different steering gear so the kit probably wouldn't work.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: Power steering into an A 100 [Re: Soopernaut] #2525028
07/21/18 04:55 PM
07/21/18 04:55 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Based on the angles involved, maybe a late Ram Van 1500 steering box could be a retrofit?
Re: Power steering into an A 100 [Re: 2002bluert] #2525094
07/21/18 08:07 PM
07/21/18 08:07 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
there is a 4 wheel drive setup that uses a modern hydraulic ram that is better than the old power ram add on things that rodstrace mentioned....
