Stud sizes (Ammeter & Starter Relay) #2523778
07/18/18 08:11 PM
07/18/18 08:11 PM
North of the Motor City
DartGTDan Offline OP
My buddy has a 1963 Dodge 440 (with a 383). He has asked me to help him with the Mad Electrical ammeter bypass. So, I'd like to get some things prepared prior to the job.
What size are the studs on the factory ammeter? My '71 Dart GT has #10 studs on the ammeter. Would the '63 440 be the same size?
Also, what size is the starter relay's BATTERY stud? Again, same as my '71 Dart GT? I assume the starter relays can/will interchange.
As always any guidance is appreciated.
Re: Stud sizes (Ammeter & Starter Relay) [Re: DartGTDan] #2523820
07/18/18 10:23 PM
07/18/18 10:23 PM
CA
crackedback Online content
crackedback  Online Content
CA
Starter relay should be 5/16"
I'm not a fan of the Mad approach. I run a wire from alt to starter relay, bypass ammeter and leave the original black charge wire on the alternator (if in good shape).
Simple, no cutting of the wiring required. Feeds the interior using factory path.
Re: Stud sizes (Ammeter & Starter Relay) [Re: crackedback] #2523899
07/19/18 01:18 AM
07/19/18 01:18 AM
I too don't agree with the Mad bypass. I do Nachos' bulkhead parallel bypass (only) & clean ALL terminals/connections (including ground paths). I like my ammeter (+ an added voltmeter) & relaying the AC/heater/headlights directly to the alt is a good move.
Re: Stud sizes (Ammeter & Starter Relay) [Re: DartGTDan] #2523905
07/19/18 01:41 AM
07/19/18 01:41 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Ammeter studs are #10-32 and relay stud is 5/16"-24.
Re: Stud sizes (Ammeter & Starter Relay) [Re: DartGTDan] #2524249
07/19/18 09:33 PM
07/19/18 09:33 PM
Thanks guys!
We plan to add a wire from the alternator to the starter relay stud, then a 2nd wire from the battery + to the ammeter "input" stud.
The headlamps are also going to be put on relays.
Re: Stud sizes (Ammeter & Starter Relay) [Re: DartGTDan] #2524279
07/19/18 10:45 PM
07/19/18 10:45 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Interesting; what gauge wire (alt/start relay)?
Re: Stud sizes (Ammeter & Starter Relay) [Re: topside] #2524757
07/20/18 09:34 PM
07/20/18 09:34 PM
We're adding a 12 gauge wire with a 16 gauge fusible link.
