Re: What will it run with a new gear
[Re: stumpy]
#252333
03/13/09 11:49 AM
03/13/09 11:49 AM
Posts: 1,178 Indy
FlyFish
Indy
if you can hook...id say 7 tenths.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: Cab_Burge]
#252336
03/13/09 01:25 PM
03/13/09 01:25 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I wouldn't expect a big change, maybe two to four tenths, maybe none It all depends on a lot of other things like converter stall, fuel and intake system and so on, please let us know your results. It will feel a lot better to you so please post the results
I'll say big change. That's a huge improvement in gearing. if it hooks you'll drop 7 thenths or more. each tenth at the 60 foot you save is worth 2 down track.
[Re: Cab_Burge]
#252337
03/13/09 01:25 PM
03/13/09 01:25 PM
Posts: 33,110 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
2.4 60',no traction troubles, 275/60/15 tires, 2500 stall conveter, 750 cfm on a dual plane eldebrock intake. I belive the 1/4 mph was 97. Felt like it took two days to get going even with me loading it to 2000 on launch. I run motly 1/8th mile tracks.
[Re: BSB67]
#252339
03/13/09 02:16 PM
03/13/09 02:16 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
Are you taking it to the TMCA race at Kennedale sunday?
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
[Re: stumpy]
#252341
03/13/09 05:14 PM
03/13/09 05:14 PM
Jacob Pitt
Mansfield, Tx
Well good luck I'll probably stop by there Sunday. I'll be racing there Saturday if they let us.
[Re: stumpy]
#252343
03/14/09 07:42 AM
03/14/09 07:42 AM
Posts: 1,086 Baton Rouge, La.
StandOnIt
Baton Rouge, La.
408,727,4100lbs,5800rpm,67mph at the 1/8th.
Try shifting in down lower where that thing is making more power, like around 5100 or 5200 rpm. You will be amazed.
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
