Carter AVS Rebuild Kits - What brand? #2523150
07/17/18 04:35 PM
07/17/18 04:35 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
I need to purchase a carb rebuild kit for a SB and BB 4-barrel Carter AVS carbs. Any recommendation on brand/where to purchase?
Re: Carter AVS Rebuild Kits - What brand? [Re: vinnyd76] #2523208
07/17/18 06:20 PM
07/17/18 06:20 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Try allcarbs.com, AKA Allstate Carburetor. The Edelbrock kit for their Thunder series should also work, I think. That's essentially an updated AVS.
Used an Edelbrock kit for their AFB-style carbs on an AFB of mine.
Re: Carter AVS Rebuild Kits - What brand? [Re: vinnyd76] #2523293
07/17/18 10:22 PM
07/17/18 10:22 PM
My carb man, John at "the carb shop" (50+yrs exp) said to avoid Tomco kits.
Re: Carter AVS Rebuild Kits - What brand? [Re: vinnyd76] #2523333
07/17/18 11:20 PM
07/17/18 11:20 PM
crabman173
crabman173
Echlin kits from Napa are great for carters
Re: Carter AVS Rebuild Kits - What brand? [Re: vinnyd76] #2523335
07/17/18 11:23 PM
07/17/18 11:23 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the two real issues are the top gasket and accelerator pump ('69 and later are larger than '68). I haven't found a good complete kit. some edelbrock stuff will work but pretty sure the top gasket won't.
Re: Carter AVS Rebuild Kits - What brand? [Re: vinnyd76] #2523361
07/18/18 12:08 AM
07/18/18 12:08 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Kits and kit components are constantly changing, most changes are not for the better. I often end up using parts from various sources to cherry pick the best of each. In general I agree that the NAPA/Echlin kits are good, and also kits sourced from Walker Products in California.
Re: Carter AVS Rebuild Kits - What brand? [Re: vinnyd76] #2523615
07/18/18 03:04 PM
07/18/18 03:04 PM
BlueRacer69 Offline
BlueRacer69  Offline
So whats wrong with tomco kits? I have one for my 4640 Carter that I've been hanging on to for years now in case I ever needed a rebuild. It must have 50 or 60 little tiny parts in the still sealed bag.
Re: Carter AVS Rebuild Kits - What brand? [Re: BlueRacer69] #2523671
07/18/18 04:58 PM
07/18/18 04:58 PM
I don't have the answer for that question as far as actual experience as this is second hand info from him so I put it out there like that as third party info (but I was very impressed with him) as I was way too busy trying to write down/remember all the excellent tech he was laying on me (for free) to ask specifically but I would assume poor quality/fitment. I'm sure he will tell you & he takes calls on Monday & Tuesday only. John 573 392-7378 I'm assuming inferior quality of some sort & I have seen many gaskets in various brand kits that the holes are slightly off especially cluster gaskets. No overseas brass floats was another caveat he mentioned (poor quality solder that can leak over time iirc).
Re: Carter AVS Rebuild Kits - What brand? [Re: vinnyd76] #2523770
07/18/18 07:46 PM
07/18/18 07:46 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
The last oem Carter carb I rebuilt I used the kit from mikes carburetors. Worked perfect. Customer likes it better than his fuel injection conversion.
Re: Carter AVS Rebuild Kits - What brand? [Re: vinnyd76] #2523774
07/18/18 08:01 PM
07/18/18 08:01 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
I've seen some crummy components in Tomco kits. I've always had good luck with Standard/Hygrade/Sorensen rebuild kits - all 3 are from the same manufacturer. I'd use them on anything, except 4150/4160 Holleys - there are better makers for a holley, including holley. The last AVS kits I got some years ago came from Year One and they were OE Carter kits.
Re: Carter AVS Rebuild Kits - What brand? [Re: vinnyd76] #2523785
07/18/18 08:41 PM
07/18/18 08:41 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Tomco carbs and kits got junky in the early 90s while I was in a USAF motor pool buying repair parts. Anytime carb work was required, a Tomco rebuilt and an Echlin kit would get requisitioned, then the rebuild was rebuilt and installed and tuned. Heck Tomco couln't even get the floats set right.
Pretty bad when voiding the warranty was a non issue.
(Also I learned you can overheat a 727s and TH400s enough to melt the case, but that is a story for another time.)
Re: Carter AVS Rebuild Kits - What brand? [Re: A990] #2523793
07/18/18 09:02 PM
07/18/18 09:02 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Here is where I have gotten all the parts to rebuild my AVS carbs. They have all the "kit" parts and stuff that doesn't come in the kits. twocents
Re: Carter AVS Rebuild Kits - What brand? [Re: topside] #2524037
07/19/18 12:34 PM
07/19/18 12:34 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I don't think the gasket for the top/bowl is the same , looking at ta thunder series it's a performer with the rear butterfly weight plate removed and a spring loaded air door added , it still has the AFB style rear venturi setup and a real AVS does not.
Re: Carter AVS Rebuild Kits - What brand? [Re: vinnyd76] #2524054
07/19/18 12:56 PM
07/19/18 12:56 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the edelbrock avs is modeled after the the mid '60's chevy avs. the only major deviation from the chevy avs is the fuel inlet. a mopar avs top won't fit on any edelbrock carb without mods. I wish there was a way to buy the edelbrock avs top because I want to convert a 1407 edelbrock to a mopar configuration.
Re: Carter AVS Rebuild Kits - What brand? [Re: Skeptic] #2524069
07/19/18 01:35 PM
07/19/18 01:35 PM
Eugene, Oregon
Secret Chimp Offline
Eugene, Oregon
+1 for QuadrajetParts. I used them for both my AVS and my Caddy Q-jet, they are a quality operation.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
