NP435 to over drive trans options #2522703
07/16/18 06:35 PM
07/16/18 06:35 PM
Guitar Jones Offline OP
Just looking for ideas here. I'd like to keep the stick in my 74 Power Wagon with what will be a Magnum 5.2 as the 4.10 gears and no O/D really make for a miserable cruise down the highway. I have a 46RH behind the Magnum engine that will be going in the truck but I'd rather avoid that if possible. Are there any manual O/D transmissions that will bolt in without a lot of fabrication? This truck still has mechanical clutch linkage and that would be easy to keep. I don't have a problem moving the divorced transfer case or the shifter hole just looking for something where the major stuff is simple. Any advice and info would be appreciated.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: NP435 to over drive trans options [Re: Guitar Jones] #2522751
07/16/18 07:51 PM
07/16/18 07:51 PM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
NV4500
Easy....sort of. (ask Scratch)
Not to hijack, is it possible to make 4th gear in a NP435 more freeway friendly?
Re: NP435 to over drive trans options [Re: Hugh Jorgan] #2522825
07/16/18 10:18 PM
07/16/18 10:18 PM
IN
ahy Offline
ahy  Offline
IN
The 4500 is a stout transmission... and from memory has .73 OD. With the aerodynamics of a '74 PW not sure the 5.2 will like pushing that truck in OD.
If tire size is original (?29" OD) may be OK with 4.10 rear. With big tires I think the 1.00 final drive in the NP 435 will work better.
Re: NP435 to over drive trans options [Re: ahy] #2522894
07/16/18 11:49 PM
07/16/18 11:49 PM
MN
58pwrwgn Offline
58pwrwgn  Offline
MN
Bigger tires? I run 9.00 x 16 (36") on my powerwagon. My rpm's are around 2000.
I would think a mid 90's dodge 5 speed would be cheapest. Not sure if it would bolt to your bell, and I think the 5 speeds use a hydraulic bell. If you are going to use the dodge computer, the crank position wheel is machined in the back of the flywheel, so you will need a 5.2 flywheel.
Re: NP435 to over drive trans options [Re: Guitar Jones] #2522913
07/17/18 12:38 AM
07/17/18 12:38 AM
ohio
bbtrux Offline
bbtrux  Offline
ohio
Do the 46RH. The other options are expensive , and honestly more work. Anythings better than an old school "spoon in a bowl of pudding" granny gear 4 speed.
Re: NP435 to over drive trans options [Re: ahy] #2522977
07/17/18 10:08 AM
07/17/18 10:08 AM
It's not much different then the 92 to 93 trucks and they did OK. I have stock size tires on it LT235/85R16 they are about 31" tall.
Re: NP435 to over drive trans options [Re: 58pwrwgn] #2522978
07/17/18 10:09 AM
07/17/18 10:09 AM
I already have a 5.2 flywheel as I was going to keep the NP435.
Re: NP435 to over drive trans options [Re: Guitar Jones] #2522980
07/17/18 10:10 AM
07/17/18 10:10 AM
scratchnfotraction Offline
if it has a divorced xfer. I have a 2x NV4500 granny five speed that is only a couple inches longer than the 435 4 speed.
have all the hydro clutch set up to go with it.
Re: NP435 to over drive trans options [Re: bbtrux] #2522981
07/17/18 10:10 AM
07/17/18 10:10 AM
laugh2 I actually don't mind the shifter and I may just keep the 435 for the time being and hold on to the auto trans and wait and see how I like it first.
Thanks for the replies. I appreciate it.
Re: NP435 to over drive trans options [Re: Guitar Jones] #2522982
07/17/18 10:13 AM
07/17/18 10:13 AM
also if you need a 360 fly and a good spare 435 4 speed mech bell sitting next to it.
Re: NP435 to over drive trans options [Re: scratchnfotraction] #2522995
07/17/18 10:54 AM
07/17/18 10:54 AM
Thanks Mike.
Re: NP435 to over drive trans options [Re: Guitar Jones] #2523294
07/17/18 10:24 PM
07/17/18 10:24 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
I've got a 77 crew with NP445 and married 203. I've got 4.56 gears and am seriously considering going to 3.54. but you have the advantage of divorce case.
I ran 900*16 for a year, not enough to make up the gears and rubbed the fenders.
If you insist on stick, I'd go 4500, if you're ok with auto run the 46rh. Both are fairly easy swaps.
Angry white pureblood male
