Any luck with aftermarket fuel gauges? #2522195
07/15/18 04:25 PM
07/15/18 04:25 PM
fresno
hyefatman Offline OP
fresno
Any luck with aftermarket fuel gauges? Brand?
Re: Any luck with aftermarket fuel gauges? [Re: hyefatman] #2522206
07/15/18 04:48 PM
07/15/18 04:48 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Are you talking about the gauge in the dash or the tank sending unit or both as set?
Re: Any luck with aftermarket fuel gauges? [Re: hyefatman] #2522267
07/15/18 08:32 PM
07/15/18 08:32 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I have a SpeedHut that has an adjustable calibration, you set the min/max. It seems to be working okay in the 'Cuda, but I do struggle with trusting it completely.
I know I'm good down to about 1/8 tank, I haven't ventured lower. "E" depends on when you can't suck fuel anymore, which is not necessarily the bottom of the tank, at least with an EFI setup that requires constant fuel pump coverage.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Any luck with aftermarket fuel gauges? [Re: hyefatman] #2522367
07/16/18 12:07 AM
07/16/18 12:07 AM
fresno
fresno
Anything that would work with stock sending unit.
Re: Any luck with aftermarket fuel gauges? [Re: hyefatman] #2522545
07/16/18 01:45 PM
07/16/18 01:45 PM
BlueRacer69 Offline
BlueRacer69  Offline
Highly doubtful.
Re: Any luck with aftermarket fuel gauges? [Re: BlueRacer69] #2522665
07/16/18 05:15 PM
07/16/18 05:15 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Highly doubtful.
Double check with speedhut but I’m pretty sure you can make it do whatever you want. I hit the button on empty, hit it again on full and it’s calibrated...
2020 RAM 1500
Re: Any luck with aftermarket fuel gauges? [Re: hyefatman] #2522670
07/16/18 05:23 PM
07/16/18 05:23 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
i put an autometer in my truck. works great.
Re: Any luck with aftermarket fuel gauges? [Re: krautrock] #2522682
07/16/18 05:53 PM
07/16/18 05:53 PM
fresno
fresno
was it AutoMeter Traditional Chrome Analog Gauges 2519 ?
Re: Any luck with aftermarket fuel gauges? [Re: hyefatman] #2522687
07/16/18 05:59 PM
07/16/18 05:59 PM
Andrewh Offline
Andrewh  Offline
actually there were quite a few. you just have to look for ones that read 12-78 ohms or something close to that and it would work with the stock sending unit. all the big makers had one last time I looked.
https://www.autometer.com/gauges/american-platinum.html#2&profile=products
shows 3 different ohms and the 10-73 is closest.
https://www.autometer.com/2-fuel-level-73-e-8-12-f-ford-chry-silver.html
that one would work with the stock sending unit.
Re: Any luck with aftermarket fuel gauges? [Re: hyefatman] #2522692
07/16/18 06:13 PM
07/16/18 06:13 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I have used Autometer and now run an Intellitronix led gauge.
https://www.intellitronix.com/fuel
I had some fuel accuracy issues and the reason for the gauge swap.
I found that it really matters if your sender is accurate as well. As for the fuel level anxiety, the only real way to know is to fill up your tank and drive the car until it runs out of fuel haha!
I was driving back from Big Willow to Norcal and ran out of gas at the 250 mile mark. Luckily it was right at an exit with a gas station. I filled up and my supposedly 22 gallon fuel cell only fit 17 gallons, so 14.7 mpg. I hadn't filled the fuel cell completely and the foam takes up some space reducing the capacity.
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Any luck with aftermarket fuel gauges? [Re: RylisPro] #2522705
07/16/18 06:39 PM
07/16/18 06:39 PM
Guitar Jones Offline
I just wanted to say, I love your car! I have nothing to add to the fuel gauge discussion.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Any luck with aftermarket fuel gauges? [Re: hyefatman] #2523929
07/19/18 03:44 AM
07/19/18 03:44 AM
fresno
fresno
installed AutoMeter Traditional Chrome Analog Gauges 2519 works great
