Suggestions - making/buying rig for frnt of car to transport #2522606
07/16/18 03:34 PM
07/16/18 03:34 PM
Ball Ground, Georgia
Dixie Offline OP
Dixie  Offline OP
Hey guys,
I need to transport a painted car shell several hours. The car has the rear-end under it, but nothing for the front. Looking for suggestions on building or buying something to attach to the front of the car for a long distance haul. I don't want to install the k-frame and associated suspension. Car will be in enclosed trailer.
Thanks in advance for any ideas!
Randy
Dixie Restoration Parts
Phone -(770) 975-9898
Phone Hours: M-F 10am-5pm EST
website: www.dixierestorationparts.com
email: mail@dixierestorationparts.com
Veteran owned small business
The Best Parts at a Fair Price.
Re: Suggestions - making/buying rig for frnt of car to transport [Re: Dixie] #2522609
07/16/18 03:42 PM
07/16/18 03:42 PM
Portland, OR
shawge Offline
shawge  Offline
Portland, OR
Take a look at the USCT body dollies. I made a copy of the fronts when I rolled around my E-body w/ rear.
Re: Suggestions - making/buying rig for frnt of car to transport [Re: Dixie] #2522620
07/16/18 03:48 PM
07/16/18 03:48 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
Years ago I made a trailer axle mount to the front of my Plymouth using the k frame mounts. It was on for sandblasting through paint and worked well.
Have a great day
Iowan
"obsolete is neat"
Re: Suggestions - making/buying rig for frnt of car to transport [Re: Dixie] #2522633
07/16/18 04:09 PM
07/16/18 04:09 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
If you have a rotisserie, just use the front section of it or get some dollies/buy a pair. You could even use them without the wheels and lift it and roll on rear.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Suggestions - making/buying rig for frnt of car to transport [Re: Silver70] #2522639
07/16/18 04:16 PM
07/16/18 04:16 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I used the front bumper bracket bolt holes for an attachment point.
Big diameter wheels are your friend if your going over uneven surfaces.
Re: Suggestions - making/buying rig for frnt of car to transport [Re: Dixie] #2522662
07/16/18 04:59 PM
07/16/18 04:59 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Cut some angle steel and attach to where the K frame mounts. weld 2 down bars with heavy duty tires that pivot with a side to side cross bar ( an axle so to speak ) then run 2 diagonal cross braces from side to side.
I don't have any pictures but made my own in an afternoon. Cost me maybe $100 and a few hours time
Re: Suggestions - making/buying rig for frnt of car to transport [Re: Dixie] #2522667
07/16/18 05:15 PM
07/16/18 05:15 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I used the front bumper mounting locations for my stands. 1/4" plate bolted to the frame with square tubing welded to the plate. THen another 1/4" plate welded to the bottom to mount the casters. My Challenger was hauled from Iowa to Ohio on these with no issues. My Dart was hauled to and from the body shop(1 1/2 hours each way) with them too.
Once my Challenger was painted, I partially assembled the car with them installed. I added larger wheels and some cross braces for my piece of mind. I used a 2x4 to tie the front stands together. It worked fine.
Re: Suggestions - making/buying rig for frnt of car to transport [Re: burdar] #2522848
07/16/18 10:47 PM
07/16/18 10:47 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I transported my done Dart body 55 miles in an enclosed trailer with the typical 3/4" floor and the right front caster fell through the floor and messed up the fender! Make sure if you do use a caster setup like shown above put a couple of decent sized plywood sheets underneath them. I have done it again with several other cars with no issues, just tie the two casters together across the front and cross tie the straps.
JB Rhinehart, Realist
A-Body's RULE!
Re: Suggestions - making/buying rig for frnt of car to transport [Re: Dixie] #2523081
07/17/18 02:55 PM
07/17/18 02:55 PM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
When I transported my painted body from NC to NJ in my enclosed, I made a box support frame out of cheap soft pine 4x4 lagged together. They were soft enough to not damage the chassis paint where it touched and then I could ratchet strap the body tight to the trailer floor. No movement.
It did take some time to get onto and off of the frame, but worth the time spent.
The freaky thing that did happen, was the metal crank handle from the roof vent worked free (screw fell out) and fell onto my car. It hit the very back edge of the hood at the cowl and stuck in there. It did chip the hood, but no dent. That was a heart stopping moment. I have since loctited these screws in place.
Re: Suggestions - making/buying rig for frnt of car to transport [Re: Dixie] #2524432
07/20/18 10:52 AM
07/20/18 10:52 AM
Dixie Offline OP
Dixie  Offline OP
Thanks guys, great info as always!
