Can someone give me advice (read) on these plugs? #2522363
07/15/18 11:57 PM
07/15/18 11:57 PM
Toronto, Ontario, Canada
plazomat Offline OP
plazomat  Offline OP
I pulled these from a running 318. I can't decide if the motor is running right - or rich...also the wet plugs kinda worry me - feels like oil.
Can someone point me in a direction - is the motor or tune ok?
Let me know if you can't see the attachments.
Plaz
Re: Can someone give me advice (read) on these plugs? [Re: plazomat] #2522396
07/16/18 02:05 AM
07/16/18 02:05 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Dual plane intake? No 4 corner idle?
Re: Can someone give me advice (read) on these plugs? [Re: plazomat] #2522397
07/16/18 02:43 AM
07/16/18 02:43 AM
I would try leaning down the idle circuit by turning in the idle fuel mixture screws a 1/2 turn leaner and then go drive it for a 1/2 hour+ and take another look at them to see if they look more to your liking or not twocents scope
I don't like to see any oil, shiny, on the plug parts inside the combustion chamber, not good tsk
Two or more ways for oil to get into the combustion chambers, bad rings and cylinder walls, bad valve seals and loose valve to guide clearances and or intake manifold gaskets leaking oil into the intake ports, all of them can be fixed wrench
I would do a leak down(or compression test) test first, dry and wet. If good then I would remove the valve covers and look inside the valve springs at the valve seals to see how they appear to you scope
if those items look good then think about checking out the intake gasket sealing shruggy
Good luck, let us know what you find and do thumbs
Re: Can someone give me advice (read) on these plugs? [Re: plazomat] #2522434
07/16/18 09:45 AM
07/16/18 09:45 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
i'd try a step hotter and do some leaning on the mix. can't see the strap to check timing. i'm finding the gasoline to be gummy; or at least the fuel in my area is. if there's a black "runny-gum" on the plugs let them sit over night and see if the gum dries up. I don't think oil will dry up but gas might.
Re: Can someone give me advice (read) on these plugs? [Re: plazomat] #2523249
07/17/18 08:28 PM
07/17/18 08:28 PM
plazomat Offline OP
plazomat  Offline OP
Thanks guys,
I will try leaning the mixture. I have new plugs in it, autolite 65's, gapped at 45, due to GM HEI installed.
Will give it a workout this weekend and pull a few plugs and post pics.
I am pretty sure that I have an intake manifold leak somewhere - how does that pull oil into the chambers?
Plaz
Re: Can someone give me advice (read) on these plugs? [Re: plazomat] #2523259
07/17/18 09:02 PM
07/17/18 09:02 PM
Originally Posted By plazomat
Thanks guys,
Plaz
On those motors, SB Mopar L.A. motors, the intake manifold acts as the valley cover over the camshaft and lifters as well as the intake manifold but due to the bottom of the manifold covering the lifter valley oil can be sucked up between the intake manifold gasket and the manifold and heads scope
The stock and some of the after market intake gaskets are stamped steel, not fiber so they will leak oil into the manifold quicker than the fiber gaskets do shruggy scope
Re: Can someone give me advice (read) on these plugs? [Re: Cab_Burge] #2523340
07/17/18 11:26 PM
07/17/18 11:26 PM
plazomat Offline OP
plazomat  Offline OP
Thanks Cab,
Feeling pretty dumb for not having that one figured out...
It was a fibre gasket I put on there a few years ago, but did not use any sealant..I was a bigger nube back then smile
Intake will be off soon enough will address that then.
Thanks for the advice Gents.
Plaz
Re: Can someone give me advice (read) on these plugs? [Re: plazomat] #2523643
07/18/18 04:12 PM
07/18/18 04:12 PM
Washington
madscientist Offline
Washington
There is oil on the plugs but that thing is pig rich. Once you get the idle and cruise close you need to start cutting the shells off to look at the fuel ring.
I'd close the gap to .035 as well. The ignition looks a bit weak to me, but it's hard to tell from that angle, especially in a picture.
Re: Can someone give me advice (read) on these plugs? [Re: plazomat] #2523652
07/18/18 04:28 PM
07/18/18 04:28 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I agree with closing up the gap to no more than .040. HEI doesn't require a big gap on our mopar engines. Also agree with it being rich.
Re: Can someone give me advice (read) on these plugs? [Re: plazomat] #2523863
07/19/18 12:09 AM
07/19/18 12:09 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
$150 wideband setup sure helps get rid of a lot of guess work. twocents
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Can someone give me advice (read) on these plugs? [Re: madscientist] #2523865
07/19/18 12:10 AM
07/19/18 12:10 AM
plazomat Offline OP
plazomat  Offline OP
Thanks all,
I am gonna try and lean it out this weekend.
I give - what is cutting the shells off, fuel ring?
What angle do you need to see - the plugs are on a bench - I can snap more pics..
Thanks all
Plaz
Re: Can someone give me advice (read) on these plugs? [Re: GoodysGotaCuda] #2523869
07/19/18 12:13 AM
07/19/18 12:13 AM
plazomat Offline OP
plazomat  Offline OP
Ya Goody, wideband is in the cards soon with the EFI install that has been ready to go for a year and just hasn't happened..
Plaz
Re: Can someone give me advice (read) on these plugs? [Re: plazomat] #2523918
07/19/18 02:45 AM
07/19/18 02:45 AM
Washington
Washington
Thanks all,
Thanks all
Plaz
The fuel ring forms at the bottom of the porcelain where it meets the shell, the threaded part. If you are careful you can use a hacksaw or a cut off wheel and cut the shell off at the bottom of the threads. It makes it easier to see the fuel ring.
I need to see the center wire and ground wire up close. You should get the oil and fuel cleaned up first and then look at things closer.
I forgot to look at the timing mark to see how close that was.
