9.250" Axle Question #2522305
07/15/18 10:10 PM
07/15/18 10:10 PM
McGregor,Iowa 52157
500ciDuster Offline OP
McGregor,Iowa 52157
Are are 5.5" on 5 axles interchangable with the 4.5" on 5 9.250" axle? The A-Body cars they had different sized bearings w/big & small bolt which has nothing to do with trucks I know but just was curious
Re: 9.250" Axle Question [Re: 500ciDuster] #2522362
07/15/18 11:55 PM
07/15/18 11:55 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
I believe there was an issue with the axle, or "C" clips, or the spider gears, or the pin that holds the spider gears between some later model rears and the early year rears. Unfortunately, I sure can't remember the years of the changes. It seemed one way would make the clearance too tight, and the other way made the clearance too loose. Gene
Re: 9.250" Axle Question [Re: 500ciDuster] #2522489
07/16/18 11:48 AM
07/16/18 11:48 AM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
There are two issues.
The first issue is there is a difference in length in the axles ,about a 16th of an inch. The second issue is the c-clip, they are slightly different sizes and slightly different locations, but I took care of that by trimming some length off of the 4.5 bolt axles and making custom c clips
Re: 9.250" Axle Question [Re: 500ciDuster] #2522492
07/16/18 11:57 AM
07/16/18 11:57 AM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
Check with Moser Axel's or Superior.
Re: 9.250" Axle Question [Re: 500ciDuster] #2522851
07/16/18 10:51 PM
07/16/18 10:51 PM
McGregor,Iowa 52157
McGregor,Iowa 52157
Ok thanx, were you going from small bolt to big bolt pattern?
Re: 9.250" Axle Question [Re: 500ciDuster] #2522858
07/16/18 10:59 PM
07/16/18 10:59 PM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
From big to small.
Re: 9.250" Axle Question [Re: 500ciDuster] #2522870
07/16/18 11:16 PM
07/16/18 11:16 PM
McGregor,Iowa 52157
McGregor,Iowa 52157
A guy I know needs a big bolt for a an 86 and I have a small bolt from a 77 ramcharger which has the right gear ratio and thats why I needed the info
