Re: Start retard question?
[Re: 70satelliteguy]
#2522136
07/15/18 02:27 PM
07/15/18 02:27 PM
crabman173
crabman173
Spin engine with IGN off--when spinning flip IGN "ON" That is how every race car needs to be wired--No retard needed
#2522207
07/15/18 04:49 PM
07/15/18 04:49 PM
Posts: 289 Lowes
steve660
Lowes
I tried using start retard, just made it harder to crank. Put in a MSD adjustable rotor, phased it to the cap and it was easier to crank over.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure. ..... Now its a door stop....
[Re: humpty]
#2522271
07/15/18 08:41 PM
07/15/18 08:41 PM
Thumperdart
State of confusion
I agree with crabman. I used to use the start retard and it did the same thing. The backfiring was brutal on the ring gear and starter. Same here, locked at 34 and never an issue either hot or cold.........
[Re: steve660]
#2522286
07/15/18 09:30 PM
07/15/18 09:30 PM
Posts: 3,097 back in Georgia
dthemi
back in Georgia
I tried using start retard, just made it harder to crank. Put in a MSD adjustable rotor, phased it to the cap and it was easier to crank over. If you're using the pickup in the distributor, you need an adjustable rotor for sure. Most of the backfires with start retard comes from the phase lighting up the wrong cylinder. Most racy stuff only needs 30-35 degrees, The relationship between pickup, and rotor is more for something like a stock motor that could see timing in the 40+ range. I guy at MSD told me years ago that for every thousand distributors they sell, one winds up on a race motor. He said they phase them for higher timing, because most racers lock them, and use crank triggers. no problem till you retard the timing a ton, like a start retard, or nitrous. Hence the adjustable rotor. Phase it up, and you can pull 20 on start with no backfire.
[Re: ]
#2522292
07/15/18 09:35 PM
07/15/18 09:35 PM
Posts: 961 Carson City, Nevada
RobbMc
Carson City, Nevada
Spin engine with IGN off--when spinning flip IGN "ON" That is how every race car needs to be wired--No retard needed I agree. Electronic start retard bad.
#2522294
07/15/18 09:38 PM
07/15/18 09:38 PM
RobbMc
Carson City, Nevada
I have the digital retard box in there for Nitrous use. Just One of the functions is start retard. I will give it a try without any retard and see what it does. Thanks Mike Good idea. Just make sure to put the ignition on a separate circuit from the starter so you can get the engine cranking before you turn on the ignition.
#2522337
07/15/18 10:59 PM
07/15/18 10:59 PM
Posts: 4,209 New York
polyspheric
New York
Ignition dead while cranking (doorbell switch) was how 6 volt Chevies with 12:1 CR engines ran on the street 60 years ago.
Boffin Emeritus
#2522369
07/16/18 12:12 AM
07/16/18 12:12 AM
Posts: 4,457 Washington
madscientist
Washington
How much timing are you pulling out?
#2522450
07/16/18 10:24 AM
07/16/18 10:24 AM
dthemi
back in Georgia
If you're using an msd distributor, run your timing around 30, and using the internal pickup you're always about 10-12 degrees out of phase without an adjustable rotor.
Think about it, 45 degrees between poles on the cap. So 23.5 is the center where it's a crap shoot on which pole fires. Already 10 behind, now pull 20 on the start, and now you're closer to the wrong pole. Presto, bang, pop, spin backwards and strip your starter ring. 25 at the crank is 12.5 at the cap, plus 5 for the factory, add slop and you're at the wrong pole. Add to that the resistance increase of the correct cylinder is at pressure making it harder for the current to pass. The wrong cylinder is much lower pressure so the current path is easier, which adds to the problem.
When you're adjusting your timing with the distributor, the phase is locked no matter what you do. The relationship between the rotor, and the pickup are fixed at the factory, and you can't change it without an adjustable rotor. locking the advance out doesn't change this either. They had to decide where most of the product would be used.
Start retard is your friend. Phase it correctly, and 16:1 starts like a honda mower.
#2522456
07/16/18 10:29 AM
07/16/18 10:29 AM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
make sure your phasing is correct. I use a cap with a hole in it to to see where the metal electrode on the rotor is when it's firing. set the distributor so the the leading edge of the rotor is what is lined up with the electrode on the cap. This is a real issue when using a small diameter cap like a stock mopar.
Without Data, you’re just another guy with an opinion.
