transission help, racecar to street car #2522194
07/15/18 04:24 PM
07/15/18 04:24 PM
cincinnati ohio
mcat4321 Offline OP
mcat4321  Offline OP
cincinnati ohio
i am transforming a racecar back to street duties. i have a 727 that was built with a turbo action manual VB with a brake... built together, installed and worked fine. i removed the TA-VB and installed a stock VB with a mancini kickdown cable,(checked and rechecked) now the only gears i have are PARK REVERSE AND FIRST,, it will not shift out of 1.. i tried a second stock VB, same issue.. could the trans. be modified in such a way the stock ones wont work? both stock VB long shelf life unused
Re: transission help, racecar to street car [Re: mcat4321] #2522210
07/15/18 05:01 PM
07/15/18 05:01 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
What are you using for a shifter?
Re: transission help, racecar to street car [Re: mcat4321] #2522214
07/15/18 05:07 PM
07/15/18 05:07 PM
cincinnati ohio
mcat4321 Offline OP
mcat4321  Offline OP
cincinnati ohio
had scs cheetah, now has stock slapstick.. checked and rechecked
Re: transission help, racecar to street car [Re: mcat4321] #2522216
07/15/18 05:21 PM
07/15/18 05:21 PM
cincinnati ohio
mcat4321 Offline OP
mcat4321  Offline OP
cincinnati ohio
Re: transission help, racecar to street car [Re: mcat4321] #2522252
07/15/18 07:37 PM
07/15/18 07:37 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Has the govnor been removed?
Re: transission help, racecar to street car [Re: rickraw] #2522258
07/15/18 07:50 PM
07/15/18 07:50 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yep, the governor guts are usually removed when installing a manual VB. And, if the trans has a roller rear support you won't be able to use a stock VB.
Re: transission help, racecar to street car [Re: mcat4321] #2522269
07/15/18 08:35 PM
07/15/18 08:35 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
The manual VB's are cool on the street. Why would you remove it? Put it back and shift it! You'll be much happier...
Re: transission help, racecar to street car [Re: Dave Hall] #2522283
07/15/18 09:22 PM
07/15/18 09:22 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
Agreed. Our Challenger has it and it's 100% a street car.
Re: transission help, racecar to street car [Re: dustergirl340] #2522290
07/15/18 09:34 PM
07/15/18 09:34 PM
Mo.
racerx Offline
racerx  Offline
Mo.
x3 nothing like barking tires in 2 and 3 if you can. cool
Re: transission help, racecar to street car [Re: Dave Hall] #2522297
07/15/18 09:42 PM
07/15/18 09:42 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Yep, and you eliminate that Rube Goldberg kickdown linkage.
'63 Dodge 330
11.19 @ 121 mph
Re: transission help, racecar to street car [Re: Dave Hall] #2522301
07/15/18 09:48 PM
07/15/18 09:48 PM
cincinnati ohio
mcat4321 Offline OP
mcat4321  Offline OP
cincinnati ohio
Im usually to drunk to concentrate on shifting, plus the wheel in one hand and my beer in the other makes it a bit hard
Re: transission help, racecar to street car [Re: racerx] #2522323
07/15/18 10:44 PM
07/15/18 10:44 PM
jersey
Spaceman Spiff Offline
jersey
Even cooler if you push buttons to do it!
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: transission help, racecar to street car [Re: mcat4321] #2522334
07/15/18 10:55 PM
07/15/18 10:55 PM
New York
polyspheric Offline
polyspheric  Offline
New York
I drove a street car with a converted full manual VB (Chrysler instructions, separator plate, transfer plate) in 1970.
Hated it - got pulled over many times for smoking the tires on the 1-2 shift with light throttle. Couldn't drive it on wet pavement unless the steering wheel was centered or it would loop on the shift.
Same problem with my DD now (dangerous when wet), except it retains full auto upshift and kick-down.
Boffin Emeritus
Re: transission help, racecar to street car [Re: mcat4321] #2522342
07/15/18 11:05 PM
07/15/18 11:05 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I have a Dart with a manual shift and an 8" converter. I absolutely LOVE it! It isn't the quickest thing with a 3.23 gear but it is fun! It's all about how much throttle to give it. High gear asap and drive it like you would any other car.
Re: transission help, racecar to street car [Re: mcat4321] #2522356
07/15/18 11:38 PM
07/15/18 11:38 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I drove a Slant car on the street for years with a 10" converter and 3.91 gears. I rarely used first gear and most of the time just drove in high gear. RMVB's are not that difficult on the street.
If yours has LBA you'll quickly learn not to downshift into low while moving. laugh2
Re: transission help, racecar to street car [Re: slantzilla] #2522392
07/16/18 01:41 AM
07/16/18 01:41 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
It can be done. I never down shift unless I'm on the throttle. So if I'm slow going up a hill or want to start in low instead of 2nd I'll throttle in second then click to first. Same coming out of a 25mph 90 only from high to second for a minute. If you are not hotrodding around just mimic how the thing would shift if it were full auto. It never down shifts without throttle pressure while moving. You definitely know it shifts! If you are on the throttle everyone else knows it by the chirp or fry. up
Re: transission help, racecar to street car [Re: mcat4321] #2522413
07/16/18 06:48 AM
07/16/18 06:48 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
I don't get the fascination with manual valve bodies.
Why not get a proper manual gearbox instead? 3 pedals are too confusing?
Had a reverse MVB in a mainly strip-only '71 Dart years ago. While it was 'secure' shifting on the actual strip, it felt cumbersome in every other situation.
Besides that, I can manually shift just fine in any automatic transmission I have, even the pushbutton ones.
Heck, I pretty much keep the A518 in my daily Dart in 2nd gear most of the time during city-driving, unless the situation lents to use 3rd or OD.
Whenever I don't like manual 'labor', I just put it in Drive and enjoy the ride evenso.
If you want sharper shifting, you need to install a TransGo Reprogramming kit that takes any slip out of the trans.
Re: transission help, racecar to street car [Re: slantzilla] #2522427
07/16/18 09:29 AM
07/16/18 09:29 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have an A1 brake valve body for another transmission I might use. It has an LBA and after 20 some odd years of driving a non LBA manual valve body I am not sure how well that is going to go at first lol.
68 Barracuda Formula S 340
Re: transission help, racecar to street car [Re: mcat4321] #2522435
07/16/18 09:45 AM
07/16/18 09:45 AM
UK
rb446 Offline
rb446  Offline
UK
Around 1986 we got a bit more serious with my '71 340 Cuda street/strip car and installed 4.30's, 4200 stall and a manual v-body (no brake) in the 727, standard shift pattern with factory slapstick, we also drilled some holes in the clutch drum I think it was, can't remember exactly......wow, that shifted real hard 1st>2nd, not quite so to 3rd, it would chirp the tyres on the road, almost hurt your neck, but I loved it, got used to it and where to have the revs to calm it a bit, best of both worlds a manual auto.
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: transission help, racecar to street car [Re: rb446] #2522445
07/16/18 10:11 AM
07/16/18 10:11 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
if all your wanting is a mild daily driver just sell the race tranny and buy a used stock unit throw a refresh at it and call it a day up
