Page 2 of 4 1 2 3 4
Re: Truck not performing as expected. Need help! [Re: fast68plymouth] #2521927
07/14/18 08:23 PM
07/14/18 08:23 PM
michigan
6pakdakota Offline OP
michigan
Originally Posted By fast68plymouth
Just a little tidbit...... and you may already be aware of this.......
But the fuel level setting on those demons isn’t like the old holleys(bottom of the hole).
I usually run those with the fuel sitting about 2/3 up the sight glass, set with the engine running.
Thank you. I will double check the float level. What heat range plugs do you guys recommend? I am currently running number 8 ngk plugs, but I know nothing about heat ranges.
Re: Truck not performing as expected. Need help! [Re: 6pakdakota] #2521933
07/14/18 08:47 PM
07/14/18 08:47 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
10.5:1?
I’d go with 6’s.
I don’t know where you’ve been shifting, but I’d try a couple passes shifting at like 55-5600..... see what happens.
Make note of what the rpm is crossing the stripe.
Re: Truck not performing as expected. Need help! [Re: 6pakdakota] #2522146
07/15/18 02:53 PM
07/15/18 02:53 PM
michigan
michigan
I replaced the fuel filter with a high flow filter and put on a fuel pressure gauge. The fuel pressure is dropping to about 4 psi during the run. I also recorded the tach during a pass. It looks like the converter might be flashing closer to 3500-3600 and not 3000. It looks like it might be time for an electric pump.
Re: Truck not performing as expected. Need help! [Re: 6pakdakota] #2522148
07/15/18 02:59 PM
07/15/18 02:59 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
1 3/4 headers are a little small for a 493
Re: Truck not performing as expected. Need help! [Re: 6pakdakota] #2522152
07/15/18 03:09 PM
07/15/18 03:09 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Mechanical pumps have their limitations for sure and a good electric pump when mounted and wired into relays can last for years............I'd go that route and keep fuel pressure 5-6 lbs according to what needle n seats you run............ thumbs
Re: Truck not performing as expected. Need help! [Re: 6pakdakota] #2522153
07/15/18 03:13 PM
07/15/18 03:13 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I had a Carter 6903 on my 440 with stealth heads and a similar size cam, and was dropping to 3 PSI at WOT even in 1st gear. Also had crappy Hush Thrush mufflers I originally bought just to keep it quiet temporarily when the motor was fresh. I put an Aeromotive electric on and 20 inch cash Ultra Flos. The car is quieter, way more responsive, and feels like it picked up 50-100 hp.
Re: Truck not performing as expected. Need help! [Re: forphorty] #2522154
07/15/18 03:14 PM
07/15/18 03:14 PM
michigan
michigan
It has 2” headers now.
Re: Truck not performing as expected. Need help! [Re: GTX MATT] #2522156
07/15/18 03:18 PM
07/15/18 03:18 PM
michigan
michigan
I sure hope mine does the same.
Re: Truck not performing as expected. Need help! [Re: 6pakdakota] #2522180
07/15/18 04:01 PM
07/15/18 04:01 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
You REALLY need more carb for that puppy trust me............ beer
Re: Truck not performing as expected. Need help! [Re: Thumperdart] #2522226
07/15/18 06:01 PM
07/15/18 06:01 PM
michigan
michigan
It is definitely on the long list of things to upgrade.
Re: Truck not performing as expected. Need help! [Re: 6pakdakota] #2522229
07/15/18 06:17 PM
07/15/18 06:17 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
thumbs
Re: Truck not performing as expected. Need help! [Re: 6pakdakota] #2522230
07/15/18 06:17 PM
07/15/18 06:17 PM
ohio
67mprfan Online content
67mprfan  Online Content
ohio
What RPM were you shifting at
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Truck not performing as expected. Need help! [Re: Thumperdart] #2522240
07/15/18 07:08 PM
07/15/18 07:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Dom.. I gave my buddy your number and he will
call.. if you can see if you can help him out
on his carb.. thanks
wave
Re: Truck not performing as expected. Need help! [Re: MR_P_BODY] #2522270
07/15/18 08:39 PM
07/15/18 08:39 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
wave
Cool Mike,much appreciated and will hook him up........... beer thumbs
Re: Truck not performing as expected. Need help! [Re: 67mprfan] #2522275
07/15/18 08:52 PM
07/15/18 08:52 PM
michigan
michigan
I was shifting at 5600-5700 trap at 57-5800. It looks like the converter is slipping about 12% also. I definitely have a lot of work to do on this thing.
Re: Truck not performing as expected. Need help! [Re: 6pakdakota] #2522307
07/15/18 10:20 PM
07/15/18 10:20 PM
So. Burlington, Vt.
So. Burlington, Vt.
12% slippage from a 3500 converter is pretty bad
Re: Truck not performing as expected. Need help! [Re: fast68plymouth] #2522351
07/15/18 11:31 PM
07/15/18 11:31 PM
michigan
michigan
That is what I was thinking. I don’t think an 11 inch converter should flash that high either. Lol.
Re: Truck not performing as expected. Need help! [Re: 6pakdakota] #2522374
07/16/18 12:24 AM
07/16/18 12:24 AM
So. Burlington, Vt.
So. Burlington, Vt.
That thing needs a nice 9.5”.
Re: Truck not performing as expected. Need help! [Re: 6pakdakota] #2522516
07/16/18 12:48 PM
07/16/18 12:48 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
My old SB Dart would drop to ~1 psi during a run with the mech pump. installed 1/2" feed and return and an electric pump, fuel pressure was constant but the car was no faster...YMMV
Also, it needs a bigger carb! Mine would pick up ~0.2 going from 750 to 950.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Truck not performing as expected. Need help! [Re: 6pakdakota] #2522521
07/16/18 12:56 PM
07/16/18 12:56 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Originally Posted By OUTLAWD
A lightweight!
I think the weather had to contribute a decent amount, and will agree with the others that the converter is too tight.
I have a similar mild 493 in my Plymouth, the 9.5" converter flashes to ~4400. Even the old off the shelf 10" "3000 stall" flashed to ~4k. I normally run 3.55's and a 28" tire and weigh 3700 lb at the line.
It is pretty light for an all steel 1/2 ton truck. Lol. What is your combo and what does it run? If you don’t mind me asking.
Combo:
66 Belv
493; 10.25:1
-516 heads, big valves
4150 M1 w/ FITech
520/520 260/266 @ 0.050
TTI 2" headers, 3.5 x-pipe, muffs and dumps
727; 9.5" converter, flashes to ~4400
8 3/4; 3.55's
tires vary, but normally run a 28" radial
Last year I was playing with a small plate kit, so didn't have too many runs on motor, ran 11.31 @ 118 at Milan with ~1700' air last time out, and 10.83 with a 0.050 jet in the plate...
Post up next time your are heading out, I'll try to make the trek. I used to work in Ann Arbor, so it was easy to shoot down to Milan, now I work in Pontiac...
Page 2 of 4 1 2 3 4
