door lock fix or replacement? #2521892
07/14/18 05:29 PM
07/14/18 05:29 PM
Calgary, AB
64Bel Offline OP
64Bel  Offline OP
Calgary, AB
Anyone have a source or suggestions for fixing this type of door lock? The only replacements I can find are the more common, but larger body door locks.
This is for my 69 D100.
Re: door lock fix or replacement? [Re: 64Bel] #2522028
07/15/18 04:10 AM
07/15/18 04:10 AM
North America
2002bluert Offline
2002bluert  Offline
North America
Hello I can either repair it or I might have a good used one. I am a locksmith in Sherwood Park. So you could either mail me the lock and key or find someone to bring it to me. I have A 100 trucks that use the same locks.
Re: door lock fix or replacement? [Re: 2002bluert] #2522179
07/15/18 04:00 PM
07/15/18 04:00 PM
Calgary, AB
64Bel Offline OP
64Bel  Offline OP
Calgary, AB
I need the locks changed to match the ignition too. Didn't get door keys.
I'll pm you, might be heading up that way in a couple weeks.
Re: door lock fix or replacement? [Re: 64Bel] #2522182
07/15/18 04:06 PM
07/15/18 04:06 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Did you try ebay for NOS set?
I got NOS set of two doors and ignition for my '79 for $50
Facts are stubborn things.
Re: door lock fix or replacement? [Re: larrymopar360] #2522190
07/15/18 04:17 PM
07/15/18 04:17 PM
Calgary, AB
64Bel Offline OP
64Bel  Offline OP
Calgary, AB
The older ones like I need have a larger face and a smaller body/hole in the door and a lot harder to find. Napa had the locks listed for $52 CAD, but were the later style.
edit: the earlier ones are closer to $300 CAD on ebay
Re: door lock fix or replacement? [Re: 64Bel] #2523204
07/17/18 06:02 PM
07/17/18 06:02 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Wow, $300. Sorry.
Re: door lock fix or replacement? [Re: 64Bel] #2523354
07/17/18 11:49 PM
07/17/18 11:49 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Can you take the tumblers out and make it a dummy lock? Old stuff isn’t real hard to jimmy so no biggie on security anyway. Can make them all work on the same key, any key, pocket knife, or screw driver!
I want my fair share
Re: door lock fix or replacement? [Re: SomeCarGuy] #2523429
07/18/18 03:42 AM
07/18/18 03:42 AM
Calgary, AB
64Bel Offline OP
64Bel  Offline OP
Calgary, AB
Probably not too hard to change the pins to match the ignition key..the pin cover looks to be a PITA compared to the later ones.
Main problem is that the actuator arm has fallen off because the end is no longer mushroomed and there isn't enough meat on there to use an E clip or something.
