Re: Which cam in my 1966 Fury 318
[Re: 451Mopar]
#252193
03/13/09 06:47 AM
03/13/09 06:47 AM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
66 Ive never seen a LA motor.I did have a 67 Firy that had a poly in it from the factory even though it wasnt supposed to.Easy to tell a poly.Just look at the valve covers.They only have a couple of bolts instead of the later pattern.If you need a cam most are custom grinds as the LA cam wont work.Timing set is the same and the intakes and intake gaskets are different also.Rocky
Chrysler Firepower
