Need some help wipers #2521443
07/13/18 01:25 PM
07/13/18 01:25 PM
Q
Quicktree Offline OP
Q
Need some help wiring a 3 speed wiper motor to a variable speed switch 2770378 on my pro street valiant I am building. It will be a direct wire from wiper motor to switch. I'll try and post some pics if I can remember how
Re: Need some help wipers [Re: Quicktree] #2521467
07/13/18 02:19 PM
07/13/18 02:19 PM
You might see if you can find a model/year, its wiring diagram on www.mymopar.com
Re: Need some help wipers [Re: RapidRobert] #2521506
07/13/18 04:23 PM
07/13/18 04:23 PM
Q
Q
I have a diagram, unfortunately it does not say where the wires go on the switch. I want them to go directly from the wiper motor to the switch bypassing all the factory crap.
Re: Need some help wipers [Re: Quicktree] #2521508
07/13/18 04:26 PM
07/13/18 04:26 PM
Q
Q
Is Jules the wiper man still around? I know he would help me. I asked JSrestorations, he refused to help. Something about liability, and that's ok guess who won't get any of my business..
Re: Need some help wipers [Re: Quicktree] #2521512
07/13/18 04:38 PM
07/13/18 04:38 PM
tboomer Offline
tboomer  Offline
Welcome back Tony! Unfortunately Jules passed away. angel
Re: Need some help wipers [Re: Quicktree] #2521531
07/13/18 05:29 PM
07/13/18 05:29 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Find the wiring diagram for one of the Mopars around your year for one with the 3 speed wipers. All the 3 speed wipers on Mopars I worked on use a shunt field to control speed along with some resisters built into the wiper switch to add and remove resistance in the shunt winding of the motor. I am sure I have one of my factory manuals with the wiring you need. If you cant get the wiring to easy PM me and I can take pics of the wiper wiring in one of my manuals for you and send them to you. Ron
Re: Need some help wipers [Re: Quicktree] #2521545
07/13/18 06:31 PM
07/13/18 06:31 PM
Fredericksburg Va
P
plycuda Offline
plycuda  Offline
P
Fredericksburg Va
Re: Need some help wipers [Re: tboomer] #2521678
07/14/18 12:25 AM
07/14/18 12:25 AM
Q
Q
Sorry to hear that, he was very helpful., Thanks
Re: Need some help wipers [Re: 383man] #2521679
07/14/18 12:27 AM
07/14/18 12:27 AM
Q
Q
I have the diagram, it does not show the wires coming from the terminals on the switch to the wipers
Re: Need some help wipers [Re: Quicktree] #2521712
07/14/18 02:12 AM
07/14/18 02:12 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
With a variable switch you want to find the High speed hot wire, witch I think is the brown wire. Feed that from your pos. of your variable control.
That's the easy part. The tricky part is getting the Wipers to Stop in their Parked position. But maybe you don't care about that. You can always shut them Off in the parked position by turning the variable switch off at the desired time.
Re: Need some help wipers [Re: Sport440] #2521783
07/14/18 12:48 PM
07/14/18 12:48 PM
Q
Q
Yea I did that, I would like them to work correctly. Jules told me how years ago but I lost his email
Re: Need some help wipers [Re: Quicktree] #2521795
07/14/18 01:18 PM
07/14/18 01:18 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
So, are you using a variable switch with a 3 speed motor? From what I could find, it seems like the switch has the same output continuity, but to act as a 3 speed, it needs a resistance wire in the harness for "medium", and an added resistor at the switch for "high"?
Re: Need some help wipers [Re: Quicktree] #2522010
07/15/18 01:35 AM
07/15/18 01:35 AM
Q
Q
thanks that's more info than I have found. I actually got it to run high speed the switch seems to have a resistor built in. i'll read this over and check the switch.
Re: Need some help wipers [Re: Quicktree] #2522278
07/15/18 09:00 PM
07/15/18 09:00 PM
Q
Q
here is what I have, the terminals on the switch are labeled :
P
W
F1
F2
B1
4 WIRES COMING OUT OF THE WIPER MOTOR
RED
BROWN
BLUE
LT GREEN
I have tried many different combinations, I have got high speed, made it do low speed and even rest. but not with all the wires hooked up. what I need is the right combination to the proper terminals so they work as they should.
Re: Need some help wipers [Re: Quicktree] #2522281
07/15/18 09:09 PM
07/15/18 09:09 PM
Q
Q
the B1 terminal may be BU its so small I cant see it good.
Re: Need some help wipers [Re: Quicktree] #2522293
07/15/18 09:37 PM
07/15/18 09:37 PM
illinois
rbkt65 Offline
rbkt65  Offline
illinois
i have a 69 service manual that has a b c body. all wiring with variable wipers appear to be the same- it is as follows: b goes to ign switch acc. p goes to blue wire on w/s/w motor. f2 goes to green an w/s/w motor. A goes to brown on w/s/w motor. f1 goes to red on w/s/w motor. 2 terminals are jumpered to A as switch has resistance cable and remaining wire goes to washer motor. or u can hook it up with nozzles to spray water on tires like early camaros had. Haha. if u want a pic pm me and i will send pics of them. i dont know how to load pics into puter. i can sent anyone pics. just too old to learn this puter stuff. haha.
Re: Need some help wipers [Re: Quicktree] #2522298
07/15/18 09:43 PM
07/15/18 09:43 PM
Q
Q
i'll give that a shot, pm sent thanks for the help
Re: Need some help wipers [Re: rbkt65] #2546883
09/06/18 08:16 PM
09/06/18 08:16 PM
Q
Q
just wanted to thank you again, finally got the car wired up and this worked perfect.
