Re: Dodge Durango Owmers-Likes and Dislikes [Re: DusterJeff] #2517222
07/03/18 11:08 PM
07/03/18 11:08 PM
So Cal
Sinitro Online content
Sinitro  Online Content
So Cal
Biggest issue with the early Durangos was ball joints both upper & lower...
Things got so bad with the OE parts Chrysler had a soft recall on them..
Just my $0.02... wink
Re: Dodge Durango Owmers-Likes and Dislikes [Re: Sinitro] #2518935
07/07/18 06:44 PM
07/07/18 06:44 PM
Montgomery, Alabama
RusTy/SE Offline
RusTy/SE  Offline
Montgomery, Alabama
I purchased my 2001 Durango SLT off Craigslist 5 years ago. Cost 5K and had 66,000 miles. Common white with a perfect cloth interior which had never been smoked in.
Despite four mismatched tires and iffy brakes, the Carfax showed it being bought new in New Jersey before traveling to Florida and then Alabama where I eventually purchased it. I took a chance on the (4.7) motor and trans being ok - they both had good fill levels and showed bone dry on the outside.
I had my mechanic go over things and after four new Michelins, fresh brakes, ac hose, and a ps hose, there have only been regular (Mobile 1 5W50) oil changes and I have maintained a 50/50 solution of anti-freeze and distilled water since.
Now has 108K and always get 15 city and 20 hwy.
Re: Dodge Durango Owmers-Likes and Dislikes [Re: DusterJeff] #2521305
07/13/18 01:34 AM
07/13/18 01:34 AM
federal way, WA
74chargr Offline
74chargr  Offline
federal way, WA
01 Durango 4wd SLT. Second owner 234K miles on it. The transmission was rebuilt once and now I am rebuilding the front end. Ball joints (upper) on the stock have no zerts so you have to replace them. Outer tie rods worn out also. It runs really good and has been surprisingly reliable for a high mileage vehicle.
74 Charger SE 87 Shelby Lancer 80 1 ton bread box 71 Duster rest in pieces
Re: Dodge Durango Owmers-Likes and Dislikes [Re: DusterJeff] #2521444
07/13/18 01:26 PM
07/13/18 01:26 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
I have a 2000 Durango 5.9 2wd 3.55 gear. I put a taller tire and electric fan on it and it now will get 20mpg on the highway cruising. Just my 2 cents but I would stay away from the 4.7 motor. Try to find a good used one and that will tell you all you need to know.
Re: Dodge Durango Owmers-Likes and Dislikes [Re: DusterJeff] #2521489
07/13/18 03:21 PM
07/13/18 03:21 PM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
Had an 02 with the 4.7l that I bought used and was nothing but a problem from day 1. I should have done a more thorough test drive.
Had the center console with thin armrest. I was always fighting with my girlfriend for it to rest our arms when we went for a ride in it.
had a noticeable wind noise no one could ever solve. In fact one response here when I had a post asking if anyone else had an issue was to "turn up the radio or put a flowmaster on it". Dealer brought it to a trim shop. Schmuck there used a cigarette to check the windshield for air leaks. Moron put a hole in my sun visor and then played dumb.
Later on.
Body rust around the cladding package.
Mine had the rear a/c package. There is a long line from the a/c compressor to the rear body. Mine blew out one night and was very noticeable! It's between the frame and body and not easily (or cheaply) serviced. Entire system could not be charged with the rear a/c line breached. I did buy the line which wasn't cheap even when discounted. Ended up giving it back to the dealer and had to eat the money spent. There is/was a company that made a bypass kit to eliminate the rear a/c but could never reach them. So no a/c last 2 years of ownership.
Had the brake system gone through, pads, rotors, etc - 1 year later the calipers froze and wiped out the new pads and rotors that I had to buy all over again. That one is probably on poor installation by the mechanic.
4.7 developed issues at 80K, low oil pressure, noises,.
At this point, I was pretty fed up as the Durango was a major money pit and "traded it in" LOL for $500 measly dollars. No one wanted it! Not even the salvage yards!!! And I called at least 3 of 'em.
Worst Mopar that I have ever owned despite my best efforts to maintain it. It was never neglected by me and I spent quite a bit of money on it.
I don't miss it. POS! I think every Chrysler made during the Daimler regime is cursed. My 2000 Chrysler LHS is a better vehicle but those cars have their funky characteristics (plural!) too. I won't even start on my Dad's 01 Dakota and the adventures with that thing.
Common sense is a flower that does not grow in everybody's garden
Re: Dodge Durango Owmers-Likes and Dislikes [Re: Ron_M] #2524970
07/21/18 01:29 PM
07/21/18 01:29 PM
Vesper,Wisconsin U.S.A
DusterJeff Offline OP
Thanks to everyone who replied to my question of the Durango,s....... Anybody else have comments about the Durango?????? up
Do Something..Lead..Follow..or get the {Beep} out of the way..
Re: Dodge Durango Owmers-Likes and Dislikes [Re: DusterJeff] #2525000
07/21/18 02:46 PM
07/21/18 02:46 PM
Paducah, KY USA Earth
jcruse64 Offline
jcruse64  Offline
We bought an '02 brand new, with 4.7, SLT trim, and tow package. While neither a powerhouse, nor a fuel saver, it has been extremely reliable for us for just over 150K miles currently. Pulls our 22' boat with ease, and has had to tow both my old trucks home before ,with no issues. Good road trip vehicle over the years, except for the 14-17 MPG we get, and tons of cargo room. The bad? The suspension issues already detailed, though I've only had to do the front wheel bearings so far (driving into duck hunting spots in sketchy flooding conditions, and these wheel bearings don't like that). Heated seats are too expensive to fix when they die. Blend door for rear HVAC is notorious for failing. A few places on front of frame where brake lines run hold moisture, allowing brake lines to rust out. And the brake lines fittings were a surprise, as well!! My wife loves thus vehicle, so we will probably drive it till it rusts out from beneath us.
Re: Dodge Durango Owmers-Likes and Dislikes [Re: Handygun] #2718492
11/22/19 10:07 PM
11/22/19 10:07 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
You want good serviceability but you don't want a 5.9? Not gonna get it from a 4.7. when I bought mine I passed on several to stay away from that engine. I wanted to either a 318 or a 360 or nothing.
, tried and true engines that have been around forever, a known quantity. Bought mine with 214k miles, has the 360, at 258k I did spring for a rebuild of the engine and transmission. Had a problem with the rebuild, wound up getting some bum EQ heads, guides were too tight on brand new "ready to run" heads, not the engines fault. Body is still in fantastic shape, so I decided it was worth doing. Did have a problem with the computer a few thousand miles before I pulled the engine, misfires on a few cylinders, most on #6, sent computer in and was told see solder joints came loose holding a chip on the board.
But the 1st 40k miles that we put on it were great. Drove down to Houston and Galveston from Chicago and back and it surprised me on gas mileage on that trip. Around 20 most of the time, down and back. Wouldn't have thought that.
I did replace the ball joints like the 3rd day I owned it.
If I had to buy another I would as long as it would be as rust free as this one is 03- older, and again NOT a 4.7. Around here the 04 and up ones are rotted out worse than the older ones.
Re: Dodge Durango Owmers-Likes and Dislikes [Re: volaredon] #2718554
11/23/19 08:04 AM
11/23/19 08:04 AM
NJ
rth Offline
rth  Offline
NJ
I had a '02 Durango with the 4.7. Engine ran great, but would push coolant into res tank. Leaking headgasket. Rotted exhaust manifold bolts .Pinion seal leaking. Steering shaft coupler.
Re: Dodge Durango Owmers-Likes and Dislikes [Re: volaredon] #2719581
11/26/19 09:50 PM
11/26/19 09:50 PM
Atlanta, GA, USA
Dodgevity Offline
Dodgevity  Offline
Atlanta, GA, USA
This 03' Dakota is my daily driver and it's currently at 310K mi on the 4.7L and tranny. The Durango was derived from the Dakota, so same front end and drive train. Cheapest vehicle I've ever owned when it comes to maintenance and it's servicable enough. Personally, I've seen the 4.7L do some extremely high miles... there was one guy running around with over half a million on his.
The 5.9L are great too, but I'd take a 4.7L any day, due to the fact it has COP and is a bit better on gas. Don't wanna be fussing with wires, caps and rotors at this point. The 545RFE has also been a stellar tranny... never a hiccup. Overall, the truck runs so good, I gave my Honda to my kid and drive it solo.
The 4.7 did have a small HG which I fixed ummm....*chemically,* about 40K ago.... smile
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/1938462/1.html
2003 Dodge Dakota Quad Cab SLT
4.7L V8, Automatic (545RFE), RWD
310K mi
Re: Dodge Durango Owmers-Likes and Dislikes [Re: DusterJeff] #2722311
12/07/19 02:31 PM
12/07/19 02:31 PM
iowa
copchaser Offline
copchaser  Offline
iowa
I've had 5 Durango's from 99-02. My currant one is a 01 R/T. I like them, easy to work on, ride nice, not to big or to small. The 4.7 has a bad rap. I never had any trouble with the 2 I had. The key with the 4.7 is maintenance, got to keep the oil changed and use good oil and they can't get hot. I dropped a 408 in my R/T. Mileage isn't bad, about 25 on the hwy. I've broke several posi's, the factory uses super cheap ones.
Re: Dodge Durango Owmers-Likes and Dislikes [Re: volaredon] #2722315
12/07/19 02:48 PM
12/07/19 02:48 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
You realize you responded to a thread over a year old. He's probably already gotten what he needed.
Re: Dodge Durango Owmers-Likes and Dislikes [Re: Sniper] #2722384
12/07/19 07:20 PM
12/07/19 07:20 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
yup. but as my Durango was my garage ornament for a bit, (reason further within post of mine, that you quoted)
found that thread on a search for something else.... and it seemed relevant even though it was old at that point.
Did you notice tehre have been other people reply to the thread after me but before you... sometimes it don't matter how old I guess.....
