Rear brake hardware, I need help #2521260
07/12/18 11:26 PM
07/12/18 11:26 PM
Adrian Michigan
Ram man9903 Offline OP
Adrian Michigan
I putting together the rear brakes on a 71 barracuda and only have the backing plates and drums. Where is a good source to get the rest of the hardware that goes under the drum? I need the spreader bar for the shoes, and parking brake attach point for in there too. Thanks
Re: Rear brake hardware, I need help [Re: Ram man9903] #2521268
07/12/18 11:58 PM
07/12/18 11:58 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
https://www.forabodiesonly.com/mopar/thr...-brakes.405381/
Well, you could try me, if your looking for 11's.
For your consideration.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Rear brake hardware, I need help [Re: Ram man9903] #2521280
07/13/18 12:33 AM
07/13/18 12:33 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Ever cop M body (AHB on fender tag) out there had 11" drums and will be a good donor. Other than that you'll be digging deep to find that stuff you need.
Don't be the exception.
Re: Rear brake hardware, I need help [Re: Ram man9903] #2521293
07/13/18 01:02 AM
07/13/18 01:02 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Get a good look at the shoe retaining spring hardware you find; last set I bought, the spring cups didn't fit the springs (they were packaged together), and the springs themselves could probably be used in a valvetrain, they were so stiff. It was parts-store stuff, not from a Mopar-specific vendor.
Re: Rear brake hardware, I need help [Re: Ram man9903] #2521299
07/13/18 01:12 AM
07/13/18 01:12 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
You didn't state 10" or 11", but basically everything from spring components, drums, hoses, wheel cylinders, brackets, etc, etc, you need is available from Autozone/Duralast, Dorman, even Classic Industries...here just a sample for your 71 E body
Re: Rear brake hardware, I need help [Re: Ram man9903] #2521412
07/13/18 12:06 PM
07/13/18 12:06 PM
Adrian Michigan
Adrian Michigan
10 inch. Thank you
