10.5 vs. 10.5W #2521117
07/12/18 05:26 PM
07/12/18 05:26 PM
tboomer Online work OP
tboomer  Online Work OP
Can anyone here tell me the width difference between 10.5 W slicks and regular 10.5s? Thanks!! Ted wave
Re: 10.5 vs. 10.5W [Re: tboomer] #2521120
07/12/18 05:43 PM
07/12/18 05:43 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
MOSTLY SECTION WIDTH.
JAKES AUTOMOTIVE
Re: 10.5 vs. 10.5W [Re: tboomer] #2521127
07/12/18 06:17 PM
07/12/18 06:17 PM
an8sec70cuda Offline
Never used them myself so can't say for sure, but was always told the 10.5W has a stiff sidewall too.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 10.5 vs. 10.5W [Re: tboomer] #2521138
07/12/18 06:32 PM
07/12/18 06:32 PM
Thanks!
Re: 10.5 vs. 10.5W [Re: tboomer] #2521147
07/12/18 07:04 PM
07/12/18 07:04 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
The W slick is 13.6 section width on a 29.5 tread width is 11.2
29.5 non W stiffwall is section width 13.2 and 10.2 tread width
a regular 29.5 is 13.1 section width and 10.2 tread width.
Hope this helps. This is with Mickey Thompson
But a 31 x 10.5W, the section width jumps up to 14.5 and tread width goes to 10.8
Re: 10.5 vs. 10.5W [Re: an8sec70cuda] #2521150
07/12/18 07:06 PM
07/12/18 07:06 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
10.5W comes in both flavors. Regular and stiff wall
Re: 10.5 vs. 10.5W [Re: tboomer] #2521151
07/12/18 07:07 PM
07/12/18 07:07 PM
Mine are 31x10.5W...
Re: 10.5 vs. 10.5W [Re: tboomer] #2521153
07/12/18 07:16 PM
07/12/18 07:16 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
those are the big ones, not as big as the 33 jumbos but only come one way.
The sidewalls bulge out as you know. There is no option with that size slick.
Re: 10.5 vs. 10.5W [Re: Sammy] #2521155
07/12/18 07:22 PM
07/12/18 07:22 PM
Walton's Mountain, Pa
Steve1118 Offline
Steve1118  Offline
A lot of NSS guys run the W because it is a wide tire, more than 10.5, but still has the 10.5 sidewall designation that is required.
The W is a big tire, for sure.
"Old age and treachery trumps youth and enthusiasm, every time!"
East Central Director / Chrysler Power Magazine
www.reasbeckracing.webs.com
Re: 10.5 vs. 10.5W [Re: tboomer] #2521198
07/12/18 08:47 PM
07/12/18 08:47 PM
Guitar Jones Offline
I've run both the 10.5 and 10.5W, the W is about an inch wider, pretty much the same as an 11.5 tire which I have also run. If you don't need the 10.5 designation there is no advantage from running an 11.5 tire.
Re: 10.5 vs. 10.5W [Re: tboomer] #2521200
07/12/18 08:50 PM
07/12/18 08:50 PM
Thanks! I am thinking about going to a plain 10.5... whistling If I can get a driver..
tire. [Re: tboomer] #2521259
07/12/18 11:25 PM
07/12/18 11:25 PM
Suffolk,VA
dragracedr Offline
dragracedr  Offline
Suffolk,VA
This can be confusing. Mickey Thompson has several flavors of 10.5W slicks:
28x10.5W tread width 10.9"
29x10.5W 11.2
31.25x10.5W 10.8
33x10.5W 11.2
Section widths vary but can be adjusted by using a narrower rim than suggested by the tire manufacturer. This comes as a caveat - cupping of the tread with less contact patch. There's nothing wrong with a non-W slick but run a 10-12 rim width with the the tallest tire having the tread width you desire. A 29" diameter tire with 10" tread with has a larger contact patch than a 28" diameter slick with the same tread width. Same applies for a W tire. The NHRA stockers run the tallest 9" wide slick they can fit for this very reason. You need to do the math for tire diameter that matches your desired maximum safe piston speed and finish line RPM. Rim offset for clearance combined with section width is at your discretion. Also a stiff sidewall is probably best for a heavy or high horsepower ride. I run a 31.25x10.5W non stiff in 2675# Coronet, on a 12" wide wheel,but only to meet the 10.5 NSS tire tread limit. In all honesty I don't need more tire. It runs 9.30's with a very mild engine. Don't over tire - it's just more unsprung weight. If l you find that a regular 10.5 or 10.5W is too soft, you can always add tubes rather than go to a stiff tire.
Re: 10.5 vs. 10.5W [Re: tboomer] #2521309
07/13/18 01:39 AM
07/13/18 01:39 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Keep the W's if they fit.
69 GTX 68 Road Runner
Re: 10.5 vs. 10.5W [Re: JERICOGTX] #2521318
07/13/18 02:29 AM
07/13/18 02:29 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
[i][/i]
Isn’t that a hard call to make without knowing rim width?
Re: 10.5 vs. 10.5W [Re: tboomer] #2521333
07/13/18 04:22 AM
07/13/18 04:22 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
M/T 33X16 10.5W's here! They actually measure about 11-3/4 on the tread. Fantastic tires! I used to not like the look of them but that has done a 180. Love them!
Re: 10.5 vs. 10.5W [Re: J_BODY] #2521352
07/13/18 09:11 AM
07/13/18 09:11 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Originally Posted By J_BODY
[i][/i]
Pretty sure Ted runs a 10" wide rim. I'd rather run a 12" wide rim on that tire. I'll take the stiff sidewalls all day long, as the sidewalls will take the most beating, and be long gone before the tread is.
Re: 10.5 vs. 10.5W [Re: JERICOGTX] #2521363
07/13/18 09:29 AM
07/13/18 09:29 AM
I have a 10" wheel and run tubes. It's a real PITA to take the tires off and I would like somebody to drive a couple of no prep events for me. wave
Re: 10.5 vs. 10.5W [Re: tboomer] #2521371
07/13/18 09:46 AM
07/13/18 09:46 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I ran both the stiff w, and the standard 10.5. No debate for me on which one is the best. The w tire is better by far (as far as down track handling and traction) I felt that the standard sidewall did launch pretty comparable to the w. Never worked to much on chassis for the standard tire. Didn’t really care for the sway down track.
I would suggest keeping the w... especially considering the fact that you are planning on using it in a situation that is likely to cause some “track induced” yaw!
Re: 10.5 vs. 10.5W [Re: tboomer] #2521379
07/13/18 10:26 AM
07/13/18 10:26 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I run the 31x10.5w on 10" rim with tubes. Been 1.240 footbrake. I also tested the 10.5x29.5s. Not much difference. Car is very stable at 150, no sway. 13.5 psi
Doug
Re: 10.5 vs. 10.5W [Re: tboomer] #2521475
07/13/18 02:42 PM
07/13/18 02:42 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
My buddies run 29x10.5W tires on 10" wheels.I have the same tires stretched on to 12" wide wheels and they look huge under my car. Much more sectional width on 12" wheels.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
