Re: 10.5 vs. 10.5W
[Re: tboomer]
#2521127
07/12/18 06:17 PM
07/12/18 06:17 PM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
Never used them myself so can't say for sure, but was always told the 10.5W has a stiff sidewall too.
Re: 10.5 vs. 10.5W
[Re: an8sec70cuda]
#2521150
07/12/18 07:06 PM
07/12/18 07:06 PM
Posts: 1,823 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Never used them myself so can't say for sure, but was always told the 10.5W has a stiff sidewall too. 10.5W comes in both flavors. Regular and stiff wall
Re: 10.5 vs. 10.5W
[Re: tboomer]
#2521153
07/12/18 07:16 PM
07/12/18 07:16 PM
Sammy
Wind Gap,Pa.
those are the big ones, not as big as the 33 jumbos but only come one way. 31 x 10.5W, the section width jumps up to 14.5 and tread width goes to 10.8 The sidewalls bulge out as you know. There is no option with that size slick.
Re: 10.5 vs. 10.5W
[Re: Sammy]
#2521155
07/12/18 07:22 PM
07/12/18 07:22 PM
Posts: 2,763 Walton's Mountain, Pa
Steve1118
A lot of NSS guys run the W because it is a wide tire, more than 10.5, but still has the 10.5 sidewall designation that is required.
The W is a big tire, for sure.
"Old age and treachery trumps youth and enthusiasm, every time!" East Central Director / Chrysler Power Magazine www.reasbeckracing.webs.com
Re: 10.5 vs. 10.5W
[Re: tboomer]
#2521198
07/12/18 08:47 PM
07/12/18 08:47 PM
Posts: 20,630 in a cattle trailer down by th...
Guitar Jones
I've run both the 10.5 and 10.5W, the W is about an inch wider, pretty much the same as an 11.5 tire which I have also run. If you don't need the 10.5 designation there is no advantage from running an 11.5 tire.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
tire.
[Re: tboomer]
#2521259
07/12/18 11:25 PM
07/12/18 11:25 PM
Posts: 173 Suffolk,VA
dragracedr
Suffolk,VA
This can be confusing. Mickey Thompson has several flavors of 10.5W slicks: 28x10.5W tread width 10.9" 29x10.5W 11.2 31.25x10.5W 10.8 33x10.5W 11.2 Section widths vary but can be adjusted by using a narrower rim than suggested by the tire manufacturer. This comes as a caveat - cupping of the tread with less contact patch. There's nothing wrong with a non-W slick but run a 10-12 rim width with the the tallest tire having the tread width you desire. A 29" diameter tire with 10" tread with has a larger contact patch than a 28" diameter slick with the same tread width. Same applies for a W tire. The NHRA stockers run the tallest 9" wide slick they can fit for this very reason. You need to do the math for tire diameter that matches your desired maximum safe piston speed and finish line RPM. Rim offset for clearance combined with section width is at your discretion. Also a stiff sidewall is probably best for a heavy or high horsepower ride. I run a 31.25x10.5W non stiff in 2675# Coronet, on a 12" wide wheel,but only to meet the 10.5 NSS tire tread limit. In all honesty I don't need more tire. It runs 9.30's with a very mild engine. Don't over tire - it's just more unsprung weight. If l you find that a regular 10.5 or 10.5W is too soft, you can always add tubes rather than go to a stiff tire.
Re: 10.5 vs. 10.5W
[Re: tboomer]
#2521309
07/13/18 01:39 AM
07/13/18 01:39 AM
Posts: 10,021 MN
JERICOGTX
MN
Thanks! I am thinking about going to a plain 10.5... If I can get a driver.. Keep the W's if they fit.
69 GTX
68 Road Runner
Re: 10.5 vs. 10.5W
[Re: JERICOGTX]
#2521318
07/13/18 02:29 AM
07/13/18 02:29 AM
Posts: 13,185 aZLiViN
J_BODY
aZLiViN
[i][/i] Thanks! I am thinking about going to a plain 10.5... If I can get a driver.. Keep the W's if they fit. Isn’t that a hard call to make without knowing rim width?
Re: 10.5 vs. 10.5W
[Re: J_BODY]
#2521352
07/13/18 09:11 AM
07/13/18 09:11 AM
Posts: 10,021 MN
JERICOGTX
MN
[i][/i] Thanks! I am thinking about going to a plain 10.5... If I can get a driver.. Keep the W's if they fit. Isn’t that a hard call to make without knowing rim width? Pretty sure Ted runs a 10" wide rim. I'd rather run a 12" wide rim on that tire. I'll take the stiff sidewalls all day long, as the sidewalls will take the most beating, and be long gone before the tread is.
69 GTX
68 Road Runner
Re: 10.5 vs. 10.5W
[Re: tboomer]
#2521371
07/13/18 09:46 AM
07/13/18 09:46 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I ran both the stiff w, and the standard 10.5. No debate for me on which one is the best. The w tire is better by far (as far as down track handling and traction) I felt that the standard sidewall did launch pretty comparable to the w. Never worked to much on chassis for the standard tire. Didn’t really care for the sway down track. I would suggest keeping the w... especially considering the fact that you are planning on using it in a situation that is likely to cause some “track induced” yaw!
Re: 10.5 vs. 10.5W
[Re: tboomer]
#2521475
07/13/18 02:42 PM
07/13/18 02:42 PM
Posts: 4,564 Motor City
6PKRTSE
Motor City
My buddies run 29x10.5W tires on 10" wheels.I have the same tires stretched on to 12" wide wheels and they look huge under my car. Much more sectional width on 12" wheels.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
