62-63 B body spring hanger dimensions. #2520793
07/11/18 11:39 PM
07/11/18 11:39 PM
NW Indiana
fbs63 Offline OP
fbs63  Offline OP
NW Indiana
I'm re-doing 63 Dodge that's had the springs moved in. Whoever did it originally had no idea where the original front spring eye belonged because there were multiple holes in the spring box. Long story short I need the dimension of the front spring hanger,specifically from the front mount to the center of the spring eye.
Re: 62-63 B body spring hanger dimensions. [Re: fbs63] #2520853
07/12/18 01:30 AM
07/12/18 01:30 AM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
on my 63 Plymouth from the mounting face of the front little crossmember that the hanger bolts to is 2" to C/L of bolt and 2.5" from floor down to C/L of bolt
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: 62-63 B body spring hanger dimensions. [Re: HOTMOPR] #2520909
07/12/18 08:55 AM
07/12/18 08:55 AM
NW Indiana
fbs63 Offline OP
fbs63  Offline OP
NW Indiana
Thanks Hotmopr!
Re: 62-63 B body spring hanger dimensions. [Re: fbs63] #2520918
07/12/18 09:29 AM
07/12/18 09:29 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Dodge has a different dimension than Plymouth. Dodge is longer
JAKES AUTOMOTIVE
Re: 62-63 B body spring hanger dimensions. [Re: JAKE68] #2520932
07/12/18 10:30 AM
07/12/18 10:30 AM
moparx Online content
moparx  Online Content
by 2" ?
beer
Re: 62-63 B body spring hanger dimensions. [Re: JAKE68] #2520934
07/12/18 10:31 AM
07/12/18 10:31 AM
NW Indiana
fbs63 Offline OP
fbs63  Offline OP
NW Indiana
I have a front hanger from a 65 Dodge Coronet and I mocked it and my spring (20" front segment) in the car and it puts the rear end too far back. The hanger is 3 3/16" from front to center. I think the 2" dimension is correct.
Re: 62-63 B body spring hanger dimensions. [Re: fbs63] #2520979
07/12/18 12:35 PM
07/12/18 12:35 PM
AndyF Offline
AndyF  Offline
My chart says 2.25 inch eye depth on a '63. For '63 I don't think there is a difference between Ply and Dodge. My info says the spring hanger length difference started in 1964. '62 and '63 use the same hanger. This is all according to info that I've collected over the years but I don't have access to factory blueprints so I could be wrong about some stuff.
Re: 62-63 B body spring hanger dimensions. [Re: AndyF] #2520992
07/12/18 12:54 PM
07/12/18 12:54 PM
NW Indiana
fbs63 Offline OP
fbs63  Offline OP
NW Indiana
Thanks guys! Going to use the 2 1/4" dimension.
Re: 62-63 B body spring hanger dimensions. [Re: AndyF] #2521022
07/12/18 01:54 PM
07/12/18 01:54 PM
1964 was the first year for the B bodies with the 22 inch long front segment on the leaf springs.
Re: 62-63 B body spring hanger dimensions. [Re: Cab_Burge] #2521050
07/12/18 03:04 PM
07/12/18 03:04 PM
Calgary, AB
64Bel Offline
64Bel  Offline
Calgary, AB
On the 64 Dodge only eh. I found out the hard way on my 64 belvedere when I put in hotchkis springs using the stock hangers. Andy's AR105 short hangers fixed that. wrench
Re: 62-63 B body spring hanger dimensions. [Re: 64Bel] #2521054
07/12/18 03:09 PM
07/12/18 03:09 PM
AndyF Offline
AndyF  Offline
Yeah I learned a lot of this stuff the hard way too. Especially on the early B body cars. Mopar Performance never bothered to make hangers for the early B body cars so I had to find hangers in the yards and figure it out myself. I can't say I know it all but I did manage to piece together a pretty good collection of original hangers over the years so I can work from actual parts.
Re: 62-63 B body spring hanger dimensions. [Re: AndyF] #2521066
07/12/18 03:28 PM
07/12/18 03:28 PM
Calgary, AB
64Bel Offline
64Bel  Offline
Calgary, AB
Glad you did! It took me a while to notice the ar105's. I have the B body springs instead of the E body springs you recommend in the description but eventually clued in. I still might put your shock plates in with the weldable shock mount...the shock travel is right on the edge of not being enough.
Re: 62-63 B body spring hanger dimensions. [Re: fbs63] #2521134
07/12/18 06:27 PM
07/12/18 06:27 PM
AndyF Offline
AndyF  Offline
Yeah, the "u weld it" shock mounts solve a lot of problems by allowing the user to move the lower mount into the best location. I use them now on all of my stuff just so I can get a custom shock location. It is important to split the compression and extension travel correctly so the shock is always in the proper range.
