HVAC ISSUES / 92 B350 #2519830
07/10/18 01:00 AM
07/10/18 01:00 AM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
My church's 92 B250 has this problem. When using the heat/ac/vent, when you accelerate the airflow goes directly to what seems like the defrost vents.
Is it the switch, or is there another issue which I'm not aware of.
Thanks in advance.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: HVAC ISSUES / 92 B350 [Re: Magnumguy] #2519838
07/10/18 01:09 AM
07/10/18 01:09 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
check for a vacuum leak.
Re: HVAC ISSUES / 92 B350 [Re: Magnumguy] #2519863
07/10/18 04:48 AM
07/10/18 04:48 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Vacum leak or the vacuum check valve for the AC/Heater system is bad. When no vacuum the AC/Heater system is made to go to defrost as a safety precation. That way if you loose vacuum to the system and doors you will still have defrost to keep windows clear in winter. Ron
Re: HVAC ISSUES / 92 B350 [Re: 383man] #2519980
07/10/18 01:42 PM
07/10/18 01:42 PM
moparx Offline
moparx  Offline
i agree with ron. when i was flipping minivans a while back, the 91-95's had the same problem. most all turned out to be in the switch, or the switch connector with all the vacuum hoses. i don't remember which though........
beer
Re: HVAC ISSUES / 92 B350 [Re: Magnumguy] #2519992
07/10/18 02:13 PM
07/10/18 02:13 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
92... last of the square body's... got the 6 button control much like the 70s cars did... I have had that problem on a couple of Mopars over the years, CRS is preventing me from remembering what I had to do to fix it.
Re: HVAC ISSUES / 92 B350 [Re: volaredon] #2520071
07/10/18 04:52 PM
07/10/18 04:52 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
We are still using our 92 B 250 as well.
When towing and under extended acceleration it does the same thing.
I am calling annoying at this point, and most likely a bad check valve.
Re: HVAC ISSUES / 92 B350 [Re: Magnumguy] #2520086
07/10/18 05:16 PM
07/10/18 05:16 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: HVAC ISSUES / 92 B350 [Re: Magnumguy] #2520376
07/11/18 05:22 AM
07/11/18 05:22 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Chrysler came out with a larger vacuum check valve later for the vehicles. I think the larger check valve that has a small resivoir built into it (its about 3 inches long and 2 inches wide) came out in the mid 90's and it can be used on any Chrysler vehicle that uses vacuum for the AC/Heater system. I did see a lot of the original smaller check valves go bad. Ron
