How many .000 cut per CC on Indy 440-1 heads? #2519758
07/09/18 11:17 PM
07/09/18 11:17 PM
Cab_Burge Offline OP
I have a pair of Indy 440-1 heads that I bought used last year that needed fixing, I had them fixed and I CC both of them today. One is between 51.8 to 52.7 CC on all four chambers and the other one is between 58.2 CC to 58.8 CC, how many thousands per CC do I need to tell the machine shop to cut the large one to match the smaller one help
Thanks in advance for the help up bow
Re: How many .000 cut per CC on Indy 440-1 heads? [Re: Cab_Burge] #2519787
07/09/18 11:52 PM
07/09/18 11:52 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Flat mill .006" per combustion chamber cc.
See here Cab
http://www.indyheads.com/testcat.html
1963 Plymouth Max Wedge
1971 Barracuda
Re: How many .000 cut per CC on Indy 440-1 heads? [Re: Cab_Burge] #2519796
07/10/18 12:10 AM
07/10/18 12:10 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
My Indy catalog says .006, but dont recommend any thing smaller 62cc. Your beyond that so there still might be some guess work anyway. .006"=1cc
Re: How many .000 cut per CC on Indy 440-1 heads? [Re: mopar dave] #2519841
07/10/18 01:24 AM
07/10/18 01:24 AM
Thanks guys, both of you up
Re: How many .000 cut per CC on Indy 440-1 heads? [Re: Cab_Burge] #2520303
07/11/18 12:10 AM
07/11/18 12:10 AM
lake charles, la
sc4400 Offline
sc4400  Offline
lake charles, la
I still have my original 1993 440-1 heads. They have been milled .100 and are 55cc. I've run them that way for 20 years with no problems. Alcohol for fuel. The CR is 13.5. They are on my sons 451 now in a SC dragster and they just keep going....
