Re: automatic shifter linkage bushing - column lockout lever
[Re: gtx6970]
#2519921
07/10/18 11:21 AM
07/10/18 11:21 AM
Posts: 2,368 Wheatfield, NY
Cuda340
Wheatfield, NY
I was lucky enough that my 70 rubber grommet was pliable enough to get out and reuse. Try Brewers he has the whole lockout setup and may have that grommet separately.
[Re: gtx6970]
#2520068
07/10/18 04:48 PM
07/10/18 04:48 PM
Posts: 25,899 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Part number for the rubber grommet is 1553304, the bronze bushing is 1553305.
[Re: John_Kunkel]
#2520088
07/10/18 05:22 PM
07/10/18 05:22 PM
Posts: 21,453 It's a dry heat
gtx6970
It's a dry heat
John I came up with 2781444 for the grommet and 2781445 for the bronze bushing ( I dont need the bushing ) I found them and have 3 of them enroute . Should be here by the end of the week
[Re: gtx6970]
#2520211
07/10/18 09:12 PM
07/10/18 09:12 PM
Posts: 13,603 md
mopars4ever
md
[Re: JMCFAN]
#2520264
07/10/18 10:54 PM
07/10/18 10:54 PM
gtx6970
It's a dry heat
I found the # I came up with on ebay. Once they're here I will verify if they are correct or not
[Re: gtx6970]
#2520547
07/11/18 02:37 PM
07/11/18 02:37 PM
John_Kunkel
Rio Linda, CA
John I came up with 2781444 for the grommet and 2781445 for the bronze bushing ( I dont need the bushing Those numbers are for the manual trans column shift.
[Re: John_Kunkel]
#2520557
07/11/18 02:46 PM
07/11/18 02:46 PM
gtx6970
It's a dry heat
John I came up with 2781444 for the grommet and 2781445 for the bronze bushing ( I dont need the bushing Those numbers are for the manual trans column shift. Oooops, might be a problem
[Re: gtx6970]
#2520589
07/11/18 03:20 PM
07/11/18 03:20 PM
Cuda340
Wheatfield, NY
Is there a bronze bushing that goes in there? If so I don't have that part. Maybe one on a column shift manual trans, but for the key lock out tube tang?
