Re: kegger manifold
[Re: tjmarcus1]
#2519414
07/09/18 05:27 AM
07/09/18 05:27 AM
Posts: 20,633 in a cattle trailer down by th...
Guitar Jones
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
Re: kegger manifold
[Re: Adobedude]
#2519436
07/09/18 09:38 AM
07/09/18 09:38 AM
Guitar Jones
Re: kegger manifold
[Re: tjmarcus1]
#2519551
07/09/18 03:17 PM
07/09/18 03:17 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
They made very good low RPM TQ. My 99 dakota 5 speed I could lug around town between 1000 and 1500 RPM all day long and get decent MPG, of course it would not pull over 4500 worth doodly squat. I always wanted to play around with isolating the coolant passage and some ceramic coating on the belly pan to keep if from baking the air goin in the runners but never got around to it.
Re: kegger manifold
[Re: tjmarcus1]
#2519581
07/09/18 04:11 PM
07/09/18 04:11 PM
Posts: 4,206 New York
polyspheric
New York
I wonder if anyone cut one apart and cut away the dividing wall separating each pair of runners - which Chrysler did to raise the RPM of the long ram in 1960.
Boffin Emeritus
Re: kegger manifold
[Re: polyspheric]
#2519589
07/09/18 04:26 PM
07/09/18 04:26 PM
HotRodDave
Kalispell Mt.
Poly I have seen that done many times, I think hughes offers a CNC job to do it but they may just be pushing the air gap now as it does the same thing but much better at keeping the air cool. The kegger even in 0*F weather around here will heat up the incoming air over 100* once heat soaked.
Re: kegger manifold
[Re: tjmarcus1]
#2519731
07/09/18 10:36 PM
07/09/18 10:36 PM
HotRodDave
Kalispell Mt.
I made spacers to isolate the bottom plate from cam oil and it helped just a little like 10*, I think the hot water passage shareing a big aluminum wall with the intake air helps heat it a lot also, between the two its just an oven in there. Thats not even to mention the giant plenum means the air spends longer inside getting heated up before goinig in a runner.
Re: kegger manifold
[Re: tjmarcus1]
#2519761
07/09/18 11:22 PM
07/09/18 11:22 PM
Posts: 20,172 Park Forest, IL
slantzilla
Park Forest, IL
I think either Freiburger or Ehrenberg did an article on modifying those intakes years ago. I had the one for my Dakota R/T and was going go try it, but somebody threw it away before I could. Truck had an M-1 on it anyway.
Re: kegger manifold
[Re: tjmarcus1]
#2519864
07/10/18 04:50 AM
07/10/18 04:50 AM
Posts: 43,129 Bend,OR USA
Cab_Burge
seriously, does anyone what the design was intended to accomplish? What is a "Kegger" intake manifold? which family motor does it fit?
Re: kegger manifold
[Re: Cab_Burge]
#2519985
07/10/18 01:54 PM
07/10/18 01:54 PM
Posts: 2,119 sc
tjmarcus1
sc
I guess I assumed everyone knew. 5.9 magnum
Re: kegger manifold
[Re: tjmarcus1]
#2520032
07/10/18 03:48 PM
07/10/18 03:48 PM
HotRodDave
Kalispell Mt.
My truck spends a lot of time in 1500 to 2000 rpm range and it doesn't feel too torkey to me. They are not the best at throttle response because of the huge plenum, a much smaller plenum would probably make them "feel" more TQ but not actually show up on a dyno. Also if the thing gives it an extra 10-20 pounds of TQ VS say a carb intake it will be hard to notice in the seat of the pants. Also if your truck is an auto it just wastes the TQ down low because the converter stall is too high. Even if it does that you still have very hot air so the air that is rammed into the cylinder is hot and not very dense so some of the effect is lost there. I have installed the Hughes airgap intake and it noticably loses TQ in the very low ranges and shifts it up higher, I would take the kegger any day in a real work truck and I bet if you could truly get rid of all that heat then it will really shine.
Re: kegger manifold
[Re: tjmarcus1]
#2594300
12/19/18 04:06 PM
12/19/18 04:06 PM
Posts: 195 Coastal Maine
Mr onetwo
Coastal Maine
I know this is old but it's time for an update.Check out Marty Fletchers work with the Magnum engines here http://utawesomeperformance.com/tech-info.html Some good products and dyno results to boot. I will be doing VRP mod with a catch can to my 5.2 Dakota. There is a 5.2/5.9 Magnum group on Facebook also...much info...Marty is there also.
Re: kegger manifold
[Re: Mr onetwo]
#2594433
12/19/18 09:09 PM
12/19/18 09:09 PM
Posts: 1,061 Atlanta, GA
mgoblue9798
Atlanta, GA
We are all ears. Mr onetwo, Do you plan to do any dyno testing? Wondering if this volume reduction thing is a real improvement or just the latest gimmick. I know there are dyno numbers on the site, but I don't buy the hype until outside testing confirms the seller's claims.
