Valley pan rails #2519224
07/08/18 05:10 PM
07/08/18 05:10 PM
ky, usa
littlejohn44 Offline OP
ky, usa
i had bought a set of early edelebrock heads that i had needed to get cut down to lower chamber volume a bit. Do i need to get the valley pan rails cut back too? I tried to install new valley pan and it is a tight fit. The center of the pan bows down. All the holes line up good . I had to use a flat head to pry it up to pull it off after the heads were on. Anyone else have this problem? Wonder if i got a bad valley pan. The last one cracked down the seam where the sides bend up to bolt to rail.
Re: Valley pan rails [Re: littlejohn44] #2519239
07/08/18 06:21 PM
07/08/18 06:21 PM
AndyF Offline
AndyF  Offline
Maybe, all depends on how much the block has been cut. You might just need to get the intake face on the heads milled down.
The way to know is to bolt the heads on the block and look to see if you have a three way match where the valley rail, deck and intake face of the head meet. They should all meet at the same point.
Re: Valley pan rails [Re: littlejohn44] #2519250
07/08/18 06:48 PM
07/08/18 06:48 PM
ky, usa
ky, usa
The intake holes line up good on the heads and the block was just barely shaved to square it up. I think i know what your talking about when the meet. Im gonna check that first.
Re: Valley pan rails [Re: littlejohn44] #2519287
07/08/18 09:35 PM
07/08/18 09:35 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
I had my heads cut down, can't recall how much, and had to go with an Indy plate because of the same reason. Ended up with a brand new Edelbrock pan I had to pry off because it was too tight.
I also had a previous pan split in the same area, so I'm actually happier with the Indy setup so far.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Valley pan rails [Re: A39Coronet] #2519317
07/08/18 11:08 PM
07/08/18 11:08 PM
ky, usa
ky, usa
That's the boat im in i guess. What was the difference in the indy plate? Are they narrower?
Re: Valley pan rails [Re: littlejohn44] #2519337
07/09/18 12:09 AM
07/09/18 12:09 AM
ky, usa
ky, usa
Has anyone used the Hughes 2 piece pans? On their site they say they will fit the victors. Hard to tell by the instructions but what seals the edge to the heads. Doesnt look like it has rails that bolt to the head. It also says it has ribs to help stiffen but i dont see any in the pictures.
Re: Valley pan rails [Re: littlejohn44] #2519347
07/09/18 12:25 AM
07/09/18 12:25 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
They're more manageable to work with. If you have to, the edge can be easily sanded down to shrink the overall width. Plus, no sheetmetal edge to crack at a seam. Very solid piece.
Re: Valley pan rails [Re: littlejohn44] #2519709
07/09/18 09:21 PM
07/09/18 09:21 PM
I would stay away from any brand two piece stamped steel valley pan for any BB Mopar based on bad feed back I got from a good customer who decided to try one from 440 source and then another one from some other vendor who is a sponsor on here now down shruggy
I am using the Edlbrock single piece Victor head bolt on valley pan on my 400 block stroker bracket motor with no leaks or issues up
Re: Valley pan rails [Re: Cab_Burge] #2519728
07/09/18 10:23 PM
07/09/18 10:23 PM
ky, usa
ky, usa
Thats what I have always used with no leaks. Other than cracking down the seam i have no complaints.It was most likely my fault. But now this new one doesn't fit.
