Mounting a Mechanical Fuel Pump W/Alternator #251868
03/12/09 06:25 PM
03/12/09 06:25 PM
Mid west
Gearhead383 Offline OP
Mid west
I'm looking for some options on mounting a mech fuel pump for a Ron's Terminator system while still using a low-mount alternator? Also, what mandrel setup did you use to accomplish this? Pics appriciated!
Thanks!
Re: Mounting a Mechanical Fuel Pump W/Alternator [Re: Gearhead383] #251869
03/12/09 07:53 PM
03/12/09 07:53 PM
NC
440Jim Offline
440Jim  Offline
NC
I just put a Ron's Toilet and belt driven pump on my BB. However, I have an alternator in the stock location, and the Ron's pump mounting kit worked. I did have a crank trigger, so I modified the length of the stand offs, but that was it.
Pics is hard to see since it is pretty crowded in the front.
Re: Mounting a Mechanical Fuel Pump W/Alternator [Re: 440Jim] #251870
03/12/09 08:14 PM
03/12/09 08:14 PM
Mid west
Mid west
Jim-
Did you use the mandrel setup from Ron's? BTW, is the alt pully your using from Moroso?
I was looking at the Moroso mandrel assy that seemed to be pretty universal using different types of pullys and spacers. I ask this because the Terminator I bought use to be on a sb chevy. I have a bb mopar spacer and mount setup however, I'm missing the piece that attaches to the balancer.
Re: Mounting a Mechanical Fuel Pump W/Alternator [Re: 440Jim] #251871
03/12/09 08:34 PM
03/12/09 08:34 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Jim,
Looks good. How is the set up working for you?
Russ
Re: Mounting a Mechanical Fuel Pump W/Alternator [Re: Dabee] #251872
03/12/09 10:14 PM
03/12/09 10:14 PM
Saskatchewan, Canada
cudabin Offline
cudabin  Offline
Jim,
I just bought a Ron's Terminator for the Cuda and would really appreciate it if you could post some pictures of how you mounted your fuel cell in the front.
Thanks,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...) 70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: Mounting a Mechanical Fuel Pump W/Alternator [Re: Gearhead383] #251873
03/13/09 03:17 PM
03/13/09 03:17 PM
NC
440Jim Offline
440Jim  Offline
NC
1) I am using the Ron's crank mandrel, entire install kit.
2) I am not sure what brand the crank pulley for the alternator is, I bought it at a swap meet 9 years ago. But it looks like a Moroso.
3) I haven't been to the track yet. Weather is not cooperating. But I have run it in the garage. And yes, the alky fumes will kill you. I have exhaust turnouts to help at the track, but in the garage...
All my pulley spacing is adjusted. Including my alternator since it is a Delco 10-SI fit into the stock location.
I can't help with the fuel cell mounting. That is a tough one on a stock front end A-body. Hopefully others can give some tips.
Re: Mounting a Mechanical Fuel Pump W/Alternator [Re: 440Jim] #251874
03/13/09 03:40 PM
03/13/09 03:40 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
here's a pic of how mine is done
Re: Mounting a Mechanical Fuel Pump W/Alternator [Re: MegaDart] #251875
03/13/09 03:42 PM
03/13/09 03:42 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
dragster is a little different
Re: Mounting a Mechanical Fuel Pump W/Alternator [Re: MegaDart] #251876
03/13/09 07:48 PM
03/13/09 07:48 PM
Mid west
Mid west
Thanks guys for all the pics! It looks like I may have to relocate my alt back up to the top to fit the fuel pump. I'll have to give this some more thought.
Re: Mounting a Mechanical Fuel Pump W/Alternator [Re: Gearhead383] #251877
03/13/09 11:05 PM
03/13/09 11:05 PM
Tucson, Arizona
MRMOPAR Offline
MRMOPAR  Offline
Tucson, Arizona
Picture of fuel cell and radiator in my 68 RR with Rons terminator.
68 RR 528" INDY MAXX 07 2500 CTD Southwest International Raceway - IHRA - Tucson, AZ
