Which Scirocco Style Radiator?? #2511920
06/22/18 10:02 PM
06/22/18 10:02 PM
Alexandria, LA
Blucuda413 Offline OP
Alexandria, LA
I currently have a Ron Davis Scirocco radiator setup which has served me well with my NA engines. This older radiator seems to be rather small with a core that is only maybe 1 1/4" thick. I'm going to a forced induction setup and thought a little better radiator would be helpful. Which of the common Scirocco radiators would be best: Griffin, AFCO, Ron Davis, Champion, or some other I can't think of at the moment. It needs to be a Scirocco style because I have the shroud, fan, mount, and overflow can etc. Which would help me the most?? Thanks, Max
Re: Which Scirocco Style Radiator?? [Re: Blucuda413] #2518385
07/06/18 01:24 PM
07/06/18 01:24 PM
Alexandria, LA
Alexandria, LA
I was sure with all the hi horsepower cars out there that someone would have some experience with different Scirocco style radiators. Any inputs????
Re: Which Scirocco Style Radiator?? [Re: Blucuda413] #2518390
07/06/18 01:28 PM
07/06/18 01:28 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
I have used a couple afco's they seem to have the most options for the more economical prices.
Re: Which Scirocco Style Radiator?? [Re: Forest] #2518394
07/06/18 01:31 PM
07/06/18 01:31 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I would shy away from the Scirocco style radiators. After 2-3 years of hard use they start spreading the plastic tanks apart.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Which Scirocco Style Radiator?? [Re: pittsburghracer] #2518510
07/06/18 06:20 PM
07/06/18 06:20 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
The AFCO's and others are all aluminum...I agree though I wouldn't run a plastic tanked radiator in a drag car.
Re: Which Scirocco Style Radiator?? [Re: Blucuda413] #2518673
07/07/18 02:08 AM
07/07/18 02:08 AM
Alexandria, LA
Alexandria, LA
I'm definitely not asking about a real Scirocco radiator, I have one of those that was put away on a shelf more than 15 years ago. I'm asking about a Scirocco style racing radiator such as Forest has in the picture. I'm really asking what brand is most favored by those that need such a radiator?? Forest, what brand is that I can't really make out the name. Thanks, Max
Re: Which Scirocco Style Radiator?? [Re: Blucuda413] #2518677
07/07/18 02:25 AM
07/07/18 02:25 AM
PA.
"Little"John
"Little"John
PA.
It saids AFCO in his post.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Which Scirocco Style Radiator?? [Re: pittsburghracer] #2518804
07/07/18 01:19 PM
07/07/18 01:19 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
yes its a AFCO...
Re: Which Scirocco Style Radiator?? [Re: Blucuda413] #2519035
07/08/18 12:18 AM
07/08/18 12:18 AM
Alexandria, LA
Alexandria, LA
Thanks, beautiful car!!!!!
Re: Which Scirocco Style Radiator?? [Re: Blucuda413] #2519142
07/08/18 01:03 PM
07/08/18 01:03 PM
Alexandria, LA
Alexandria, LA
Forest, what is the part number for your AFCO radiator? I can't find a picture of one that is like yours. Thanks, Max
Re: Which Scirocco Style Radiator?? [Re: Blucuda413] #2519849
07/10/18 02:15 AM
07/10/18 02:15 AM
SE Washington
Forest Offline
Forest  Offline
SE Washington
they have a few different configurations, I changed this one from a upper hose to dual -12's for the upper and added the Meziere plate for the radiator mounted water pump..
