Page 3 of 4 1 2 3 4
Re: Ritter Blocks [Re: WHITEDART] #2518620
07/06/18 11:07 PM
07/06/18 11:07 PM
Anoka County, MN
Leigh Online content
Leigh  Online Content
Anoka County, MN
Originally Posted By WHITEDART
Basically he will cut the whole wherever it needs to be.. they do a lot of file core blocks also
This I understand. But, what about inaccurate initial boring, on a block with core shift?
Re: Ritter Blocks [Re: Biginchmopar] #2518623
07/06/18 11:19 PM
07/06/18 11:19 PM
Nampa, Idaho
Moparmatts72 Offline
Nampa, Idaho
If anyone want to see what they have, go to their website and you can see all the machines they have, it's an amazing place. It is worth the drive if you live here in Cali to see their shop.
Re: Ritter Blocks [Re: Leigh] #2519039
07/08/18 12:30 AM
07/08/18 12:30 AM
Carson City, Nevada
Biginchmopar Offline OP
Carson City, Nevada
Why are you so concerned?
Both White Dart and myself told you QMP enough said.
If you’re looking to build one of these let us know and we will get to the right people.
If you are just looking to pick at something go elsewhere.
Re: Ritter Blocks [Re: Biginchmopar] #2519050
07/08/18 01:05 AM
07/08/18 01:05 AM
Washington
madscientist Offline
Washington
Very well said. Ritter is making a product no one else would even consider. On a limited budget. He has worked his way through his teething issues. THANK YOU to all who worked with Kent Ritter and moved this project along.
As always happens, the cheap asses, whiny Chrysler guys instead of supporting this guy spend most of their time [censored] on them.
Re: Ritter Blocks [Re: Biginchmopar] #2519051
07/08/18 01:10 AM
07/08/18 01:10 AM
Nampa, Idaho
Nampa, Idaho
Leigh, they sonic every block, trust me you send a Ritter block to them, it's in very excellent hands. They really are a one stop shop for anything.
Re: Ritter Blocks [Re: Moparmatts72] #2519079
07/08/18 02:59 AM
07/08/18 02:59 AM
Anoka County, MN
Anoka County, MN
Originally Posted By Moparmatts72
Leigh, they sonic every block, trust you send a Ritter block to them, it's in very excellent hands. They really are a one stop shop for anything.
Thank you for being polite. I was not questioning the engine shop, just inquiring on the technology they use. When my rough bored 1994 R1 block was bored, Tesar Race Engines had to aquire an indexing fixture from Arrington, that was made to print specs. I see the Rmc V3 probes and compares to print. As far as sonic checking, yes, I'm sure they do. Good luck with what sounds like a good, solid platform.
Re: Ritter Blocks [Re: Biginchmopar] #2519128
07/08/18 12:15 PM
07/08/18 12:15 PM
Nampa, Idaho
Nampa, Idaho
I can see your where you are coming from, trust me I was worried too about core shifts. But this blocks due seem to be minor if not at all. Maybe not all blocks will go to the 4.220 bore they are suppose to but these blocks are solid, thick in areas that much needed it. If you or anyone has questions feel free to ask those of us that have them.
Re: Ritter Blocks [Re: Biginchmopar] #2519133
07/08/18 12:33 PM
07/08/18 12:33 PM
Mo.
racerx Offline
racerx  Offline
Mo.
I will say this, Chrysler is well over due for blocks (big and small)glad to see this. up
Re: Ritter Blocks [Re: racerx] #2519149
07/08/18 01:18 PM
07/08/18 01:18 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
We are pushing for four digits.. out of an N/A.. we have gotten close.. but not there yet the motor is back apart looking for a few more HP.. my block is still leaking water through some porosity into the crankcase.. going to try to seal that up with epoxy.. keeping the water out of the oil on this block has been a challenge.. Granite this is second generation I know Bob's block is a 3rd generation.. which I am told is a nice piece..
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Ritter Blocks [Re: Biginchmopar] #2519159
07/08/18 01:58 PM
07/08/18 01:58 PM
Nampa, Idaho
Nampa, Idaho
Very cool Shilo i know you will find that extra hp somewhere. I going for 4 digits as well with pump and race fuel.
Bob what's your goal for your build?
Re: Ritter Blocks [Re: WHITEDART] #2519204
07/08/18 04:12 PM
07/08/18 04:12 PM
Washington
Washington
Where is the porosity? I'm not all that familiar with cast iron casting and what cast iron those blocks are (I'm doubting they are CGI because they'd be more expensive) but I'm told the pour is too cold when you get porosity.
Re: Ritter Blocks [Re: Leigh] #2519412
07/09/18 04:31 AM
07/09/18 04:31 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
I believe the R series and R1 blocks were machined with factory style tooling and fixturing, which wasn't as accurate as much of the aftermarket CNC machined stuff now.
Alan Jones
Re: Ritter Blocks [Re: Moparmatts72] #2519541
07/09/18 02:56 PM
07/09/18 02:56 PM
Carson City, Nevada
Carson City, Nevada
Well if I'm going to help Shiloh against Chevy and Ford I need to be in the same ballpark (4 digits). I might have to go to the next head program to get what Shiloh is after. I have a few things I'm going to try before more head work but I'll bet the heads need to go back to Brett before we reach 4 digits.
You guys need to understand that Brett, Shiloh and a few others are getting ridiculous numbers out of these small blocks. I'll see what I can do to make sure I'm not way behind once I get my deal going.
Re: Ritter Blocks [Re: Biginchmopar] #2519568
07/09/18 03:49 PM
07/09/18 03:49 PM
Nampa, Idaho
Nampa, Idaho
I here you on that, not sure if I'll be the first to force induction these block but we shall see, nice thing with turbo there are easy in the internals. And I'll take mine out to local events to also help you and Shilo take on them. Though mine is also a street car. Will be fun either way.
Re: Ritter Blocks [Re: WHITEDART] #2519922
07/10/18 11:22 AM
07/10/18 11:22 AM
cheshire, ct
davesmopars Offline
davesmopars  Offline
cheshire, ct
There is a place that my buddy knows that fix this. Its a new process they do on porosity blocks. I well get the number for you
Keeper of the 440 M code Cuda registry
mcodecuda@yahoo.com
Re: Ritter Blocks [Re: davesmopars] #2519930
07/10/18 11:34 AM
07/10/18 11:34 AM
cheshire, ct
davesmopars Offline
davesmopars  Offline
cheshire, ct
There is a place that my buddy knows that fix this. Its a new process they do on porous blocks. I well get the number for you
Chris Adams at Metaplastics
11 Sherman St West Hartford CT 860 953 3492
He is super busy
This fixes porous blocks
**This will not fix Cracked Blocks**
mcodecuda@yahoo.com
Re: Ritter Blocks [Re: davesmopars] #2519949
07/10/18 12:02 PM
07/10/18 12:02 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Thank i will look at it
Re: Ritter Blocks [Re: Biginchmopar] #2520287
07/10/18 11:41 PM
07/10/18 11:41 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Matt.... was your block prepped for 59 degree? If so did it come that way from Ritter, or did QMP do that. Guess I’m just “assuming” looking at the machine work on the block.
Re: Ritter Blocks [Re: Biginchmopar] #2520301
07/11/18 12:05 AM
07/11/18 12:05 AM
Nampa, Idaho
Nampa, Idaho
It came that way from Ritter, QMP just inserted the sleeves and made them a little bigger to .937
Re: Ritter Blocks [Re: Biginchmopar] #2520862
07/12/18 01:52 AM
07/12/18 01:52 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Hang tight and in a little Dart will have a quality block with no worries about its quality..
Top builders are providing info on weak spots from earlier designs that needed attention.
Page 3 of 4 1 2 3 4
