pre magnum 360 heads #2518621
07/06/18 11:15 PM
07/06/18 11:15 PM
Tampa Florida
missile fan Offline OP
Tampa Florida
I have a mopar performance 360 short block
( It is the last year before the magnum )
I am looking for a set of cast iron heads for it
What is the casting numbers for the heads ?
Thanks smile
Re: pre magnum 360 heads [Re: missile fan] #2518724
07/07/18 09:53 AM
07/07/18 09:53 AM
Locomotion Offline
Locomotion  Offline
The last LA production heads that Mopar had ended in 308 They were used on production 360's from '88 or '89 through the end - 1992 I believe. The last over-the-counter OEM style heads they had ended in 576. These may have been used on the complete crate engines and there were a variety of 576 versions that were sold seperately - 1.88" valve, 2.02" valve, ported, T/A offset pushrod hole style, etc. The heads appear very similar with the most obvious difference is that the 576 heads do not have the hole under the exhaust ports for emissions.
