Re: need correct pulley for water pump 426 hemi
[Re: hyefatman]
#2518582
07/06/18 09:35 PM
07/06/18 09:35 PM
Posts: 7,664 IN
ahy
IN
I wonder what diameter crank pulley? 7"-7 1/4" range is common for OE. In general, Bouchillon has been helpful for me with pulleys, knows MOPARs and sells a bunch. I would give them a call. FWIW My BB runs a ~5" fan/WP pulley from Bouchillon. It is a "with AC" setup. https://www.bouchillonperformance.com/
[Re: hyefatman]
#2518607
07/06/18 10:48 PM
07/06/18 10:48 PM
RapidRobert
Does anyone sell or have a part number for a smaller diameter pulley? what dia/depth do you need?
[Re: hyefatman]
#2518737
07/07/18 10:30 AM
07/07/18 10:30 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Looking back at your post history, you been having overheating issues for a decade now.
What are you calling overheating?
[Re: hyefatman]
#2518791
07/07/18 12:54 PM
07/07/18 12:54 PM
Posts: 10,731 North Dakota
6PakBee
North Dakota
Sounds like the right combination. Stock '68 Hemi has a 6 5/8" crank and a 5 9/16" water pump pulley.
[Re: hyefatman]
#2518792
07/07/18 12:54 PM
07/07/18 12:54 PM
Supercuda
About to go away
About to go away
up yours
Right now, why do you think you are overheating?
190 at idle after 16 minutes at idle is not overheating.
Do you realize that there is a difference in water pumps for an AC car and a non AC car? Which do you have?
[Re: hyefatman]
#2518812
07/07/18 01:34 PM
07/07/18 01:34 PM
Supercuda
About to go away
About to go away
up yours
https://bouchillonperformance.com/inc/sdetail/868/903The with AC pulley is about an inch smaller in diameter than what you have.
[Re: hyefatman]
#2518850
07/07/18 02:42 PM
07/07/18 02:42 PM
Supercuda
About to go away
About to go away
up yours
They are talking about the original single groove water pump used in early AC setups. That used a tensioner pulley. http://www.dodgecharger.com/forum/index.php?PHPSESSID=6pp10c63acmkrcu9jccp068m41&action=dlattach;topic=82987.0;attach=154732;image Vice the later with AC setup https://www.allpar.com/photos/vintage/1977/440-1977.jpg
[Re: hyefatman]
#2518900
07/07/18 04:58 PM
07/07/18 04:58 PM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
I dont use the tensioner , I bump the belt on bypassing the tensioner
[Re: hyefatman]
#2518953
07/07/18 07:45 PM
07/07/18 07:45 PM
CSK
Pattison Texas
Are you running a street hemi with a thin damper? no Hemi just a bb, just giving you ideas
